ptv help
Old 02-22-2012, 09:43 PM
1badeagle's Avatar
Default ptv help
Just wanted to show all you guys my ptv clearances on my 6.1 lq4. The clearance was checked with stock gm .054 head gaskets, stock ls3 heads, 4.030 mahle l92 pistons. The cams specs 235/243 .621/.623 110+4.
As you can see, i have a easy. 250" on intake and .230" on the exhaust side. I can tell you that the valves would have hit the pistons if i had not had aftermarket pistons. I am planning on milling .050" of the heads and having them ported as well.
My only issue iz that when i checked ptv clearence, i used yellow springs fofget to make the lifters solid. Do you think i have enough clearence to mill. 050"?
Old 02-22-2012, 10:06 PM
Tainted's Avatar
Id recheck again to make sure but I dunno about milling that much off your heads...
I believe your ptv clearances should be at least .080 intake and .120 for the exhaust but dont quote me on that!!
Old 02-22-2012, 10:24 PM
1badeagle's Avatar
I was going to recheck tonight before work. I pulled the lifter apart to shim it up and upon reassembling it, my giant fingers let the clip move causing the lifter to shoot apart and i lost a peice of lifter in my garage somewhere. So i have to. So now i have to buy a new lifter and im scared to take another one apart.
Old 02-22-2012, 10:30 PM
Tainted's Avatar
Oh dont be afraid the worst that can happen is you **** it up
Old 02-22-2012, 10:37 PM
1badeagle's Avatar
Thats exactly what im afraid of.
Old 02-23-2012, 09:35 PM
1badeagle's Avatar
I went ahead and pulled 2 other lifters apart tonight. I pulled them apart, flipped the plunger put a small washer on top of the plunger. Then I put the little thin flat spacer thing back on and part that the pushrod rides on. I checked again with playdough and it looked exactly the same again. I will know the numbers for sure tonight after i get to work.
Old 02-23-2012, 11:11 PM
1badeagle's Avatar
Ok guys, Just check the cleareances with my caliber. I have .2245" intake and .2005" exhaust. Can I run a .040" gasket and a .050" mill on the heads?
Old 02-24-2012, 01:19 AM
1badeagle's Avatar
With the mill work and thinner gasket I will have .1635" intake and .1395" exhaust
Old 02-24-2012, 11:40 AM
DirtyDirk's Avatar
How thick is the deck surface on the ls3 heads? I would think they are thick enough but would ask before I cut them .050.
Old 02-24-2012, 05:16 PM
Tainted's Avatar
to me thats getting thin. I'd mill .040 but i dunno if personally I'd go much past that
Old 02-24-2012, 07:32 PM
Fastdriver1992's Avatar
u have plenty of clearance i've always been told .120 clearance on the intake and .080 on the exhaust and i've never had a ptv issue
Old 02-24-2012, 07:45 PM
1badeagle's Avatar
Patrick G told me .080" intake and .100" on the exhaust side.
Quick Reply: ptv help
