oil pressure question
Old 03-07-2012, 01:29 PM
Double J's Avatar
Default oil pressure question
Hi-brand new LS3 STROKED 418 CI FORGED INTERNALS,noticed oil pressure dropped from 60 to 40 today after i hammered the go pedal-any reason why? No noticeable performance change. Hope it's nothing to be concerned about, please chime in.
Old 03-07-2012, 05:33 PM
Double J's Avatar
just started car again back up to 60
Old 03-07-2012, 06:07 PM
Gray86hatch's Avatar
Oil temp will lower oil pressure.
Mine goes from 70 at idle cold to 30 with 200 degree oil temp.
As long as you are seeing good wot pressure I would not be concerned
Tim
Old 03-08-2012, 09:51 AM
LS1TECH Sponsor
Carshopinc.com's Avatar
Tim Is spot on ....
LS engine oil pressure is real sensitive to temperature and viscosity... especially with
tight HP oil pumps..
Old 03-08-2012, 05:55 PM
Double J's Avatar
Thanks I noticed it does change between 40-60 and sometimes back to 40 when temp is at operating range of 210 degrees for my motor.
Quick Reply: oil pressure question
