wheres all the lq9s?
collectively ive done about 3 hours of reading and searchin around for someone who has done a build close to what i want to do and cant find much.
last week i almost bought an ls6 shortblock to build but then i started kickin around the idea of a lq9..... then i started searchin and cant really find anything to impressive yet
my goal is to make atleast 500rwhp. id be happy at 500 but theres nothing wrong with a little more
but cant decide between a ls6 or lq9 only from what ive seen so far,
id figure a lq9 with a big ol' cam either shelf cam or spec'd out from pat g or so, along with a ported FAST intake AFR 215 or 230 heads with a small combustion champers pulleys throttle body to match the FAST long tubed and full exhuast....of course ARP all around and big injectors maybe some different pistons
are you just not going to see 500rwhp with that or not? all i can find is people using stock heads and such
would a lq9 have to be stroked or bored or both to see these numbers?
or is it gonna be the same as doing all the same mods to an ls6 with give or take 20-30 hp ?
Instead of dropping the money on afr heads, put an ls3 top end on it. I have a 370 with an ls3 top end, (stock heads and intake) and I'm shooting for 500.
People are making 500 at the wheels doing ls3 top end swaps on ls2's with a good cam. No reason it can't be done with a higher compression iron block.
Do you have any links to some of these? I'd like to see their setup compared to what I'm doing.
I'm running (in work) a 96mm TB, 1 7/8 Hooker LTs, EPS cam, 4k stall (TH400), M9 (3.89s, may go steeper but I have plans to hit it with a 100 shot), target weight is 3300-3400 with me in it and the 10pt moly cage. I'm not too concerned with a dyno #, I just want to see 10s off the bottle. However, if my setup is along the lines (at least close) with a 500 rwhp car, it should have 10s in it with the suspension dialed in. Sorry if I hijacked your thread at all OP.
nahh didnt hijack it..............terrorist...... jk haha
i just want some info from someone see some builds..some numbers.. somethin
i looked around youtube, guy had a pretty stout lq9 on a dyno...and he only made like 435 to the wheels... i have to hit at very least 500 to wheels.
"bww388" what sort of info do you have about ls3 top end? benifits over after marketed top end?
any one else feel free to put in info
btw i have an m6 and will be running 411's through a 9inch eventually
300 + cfm on the intake side bone stock...I picked up my brand new ls3 heads for 700 bucks. These heads will flow more than enough for a 6.0 right out of the box. Combine them with a custom cam, up the compression a little and put a fast intake on it, and I don't see why you wouldn't hit 500. Only problem is your either going to have to fly cut the pistons or change to a forged piston with valve reliefs. The huge intake valve does not leave a lot of room for a larger cam, although, the ls3 heads flow so good, a huge cam is not necessary. Which means less aggressive lobes and longer valve spring life, and better driveability.
hmm i hear ya, ill have to do some reading on the ls3 heads for flow #'s.
the engine will be ripped down anyways im fine with fly cutting the pistons, no big thang there. whats the numbers on your ls3 heads for reference (i.e. ls1 "243" heads) ?
Lol.
The cam I'm running is just a little more aggressive than the one that guy with the C6 is running (.600in lift and right at .100 PTVC). Also, I'm running an SD tune (gotta keep the 93 thing going lol), and a K&N 98-02 FIPK with my Ultra Z hood. Honestly, at this point, I can't justify throwing the $1k weight reduction mod to my bank account for a FAST intake setup (I'm going to continue to look elsewhere for power until I "NEED" it).
Agreed, mine is a 12* split
intake:
.200 151
.300 208
.400 256
.500 294
.600 316
exhaust:
.200 111
.300 152
.400 174
.500 183
.600 189
Data based on a 4 in bore
Even on a stock un-touched head it would make sense for more duration on the exhaust side to crutch the lower flow numbers in comparison to the intake.
