Allpro Heads pic
Are those the LSWs? If so, would you happen to know the minimum bore size on them? All Pro's website says 4.00 but West Coast's website says 4.125??
All Pro I believe designates all the LS square port as LSW, you need to know what valve spacing each head has. I don't think he has the 12-2 in smaller bores, but I believe Richard can do the 12-1 for 4 inch bore. You should call Richard with your needs.
Kurt
Kurt
call Bob ! @ all Pro or Charlie WCCH either guy is amazing if they can do the deal they will ..worth every peny ...and my old after market heads ls7 were not bad ...i made 585 threw 4l60 auto very close cam ..just not as good as all pro ...
