URGENT LS2 stretch bolt tolerances - LS1TECH
Thread Tools Search this Thread
Old 03-17-2012, 06:22 AM   #1
Default URGENT LS2 stretch bolt tolerances
Hi,
Does anyone know the stretch bolt tolerances on a LS2?
Long story short I was let down on getting new ones and need the heads on this weekend.
Thanks!
-jamie- is offline   Reply With Quote
Old 03-17-2012, 09:00 AM   #2
Technical Facepalm
crainholio's Avatar
Quote:
Originally Posted by -jamie- View Post
Hi,
Thanks!
WTF is "stretch bolt tolerance"??
crainholio is offline   Reply With Quote
Old 03-17-2012, 10:41 AM   #3
I think OP is referring to torque-to-yield? Those are single use as far as i know...
flash911 is offline   Reply With Quote
Old 03-17-2012, 10:48 AM   #4
redbird555's Avatar
it seems like you're talking about reusing headbolts which is a big NO-NO. Most autoparts stores stock the fel-pro replacements so just go there and pick up 2 sets for 25 bucks a piece.
redbird555 is offline   Reply With Quote
Old 03-17-2012, 01:41 PM   #5
Unfortunately in the UK no autopart company stores headbolts for LS2's, The engine has only done 28k miles, but i'm going to have to reuse them for mapping on thursday and just replace them when i can get them!
Old 03-17-2012, 02:07 PM   #6
Sawzall and Welder Mod
Best of luck to you.
Whistler is offline   Reply With Quote
Old 03-17-2012, 02:25 PM   #7
RacerXLs1's Avatar
Quote:
Originally Posted by whistler View Post
best of luck to you.
x2!!!!!!
RacerXLs1 is offline   Reply With Quote
Old 03-18-2012, 05:29 AM   #8
Get ARP's, or a Vauxhaul dealer might have the factory set for the Holdens sold under Vauxhaul badge. Though price will hurt, better than snapping a TTY and having to get it out later.
rsz288 is offline   Reply With Quote
Old 03-18-2012, 03:53 PM   #9
The bolts will not likely snap. They will just not clamp correctly.
Old 04-21-2012, 07:13 PM   #10
Restricted User
Quote:
dou ?
jalper is offline   Reply With Quote
Old 04-22-2012, 03:29 AM   #11
Quote:
Originally Posted by jalper View Post
dou ?
Doh?
Old 01-31-2013, 02:10 AM   #12
What about using head studs from Alper Motorsports, I think they are the same price as the stock bolts, that is what I have used in the past,
Machine-Master is offline   Reply With Quote
Old 01-31-2013, 09:23 PM   #13
LS1MCSS's Avatar
Quote:
Are they in the UK? He needs something quick.
LS1MCSS is offline   Reply With Quote
Old 01-31-2013, 09:25 PM   #14
LS1MCSS's Avatar
Quote:
Just paypal someone from here to overnight ship a set to you. Shipping will be expensive, but not as expensive as a motor.
Old 02-01-2013, 08:35 AM   #15
MX6.0's Avatar
Quote:
The thread is almost a year old. Hopefully he has it taken care of by now
MX6.0 is offline   Reply With Quote
Old 02-01-2013, 11:20 AM   #16
If not I have shipped to Canada, I think to ship a set of studs would be around $16.00 for flat rate
Related Topics
Thread Thread Starter Forum Replies Last Post
ARP Studs - Don't Fit in LS1? mOtOrHeAd MiKe Generation III Internal Engine 3 12-21-2016 12:31 PM
GM cylinder head bolts - stretch to yeld transwiz Parts Classifieds 3 05-18-2016 10:23 AM
LS2/LS3 topend build - Shortbloack clearence questions Cwarta Generation IV Internal Engine 11 11-08-2012 03:51 PM
Replacing stock rod bolts with arp's td1168 Generation III Internal Engine 8 11-05-2012 08:10 PM
mahle piston questions bradyfred77 Generation IV Internal Engine 9 09-20-2008 10:10 AM
Tags
bolt, bolts, head, ls1, ls2, reuse, stratch, stretch, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
