LS2 build (need advice)
Old 03-29-2012, 08:36 PM
cominupSS's Avatar
Default LS2 build (need advice)
i have a '99 Z28 has 150,00 and the piston rings are shot. so i ordered a 6.0 aluminum block. theres an '03 cobra runnin around talking alot of **** and i really would like to make him STFU. thinking of stock crank,forged pistons and rods, ported 243 heads LS6 intake....really would like to do a 200 shot but could settle for 150. never really build a motor but would like advice on what combos to go with and yall's thoughts. thanks and im not trying to build a drag car. just a street car with a little bang
Old 03-29-2012, 10:18 PM
cominupSS's Avatar
And an aggressive cam also
Old 03-29-2012, 10:38 PM
Mr. Sir's Avatar
LS3 heads/intake are better. 200 shot will be fine.
Old 03-29-2012, 10:46 PM
Tainted's Avatar
Ls3 heads and intake
You wont be able to run a huge cam, but do your research is you go with the ls3 top end. Donkey dick aggresive cams dont do well.
Old 03-29-2012, 10:49 PM
cominupSS's Avatar
Was think a .600 lift cam
Old 03-29-2012, 10:53 PM
Tainted's Avatar
Its not so much about lift as it is duration and overlap.
Old 03-31-2012, 09:06 AM
cominupSS's Avatar
What are some good pistons to go with?
Quick Reply: LS2 build (need advice)
