ABSOLUTE best heads for stroked ls2 (COME ON IN) - LS1TECH
Thread Tools Search this Thread
Old 04-02-2012, 12:33 PM   #1
Default ABSOLUTE best heads for stroked ls2 (COME ON IN)
Im in the process of building a 402 motor and im wanting to know what the absolute best heads are, iv been looking at...i have a 102 fast as of now and my car is a lightweight auto
-TEA trickflow 245
-TEA trickflow 235
-MAST motorsports
Price is not a concern, I race my car a TON so i want the best/most powerful i can get.
I have looked into both the trickflows but i really dont know what MAST has to offer. im thinking im staying around 11.5 CR for 93 since i do drive my car. But im not afraid of "street maners" as some call it because its not a daily...thanks
SUPAFASTSS is offline   Reply With Quote
Old 04-02-2012, 02:25 PM   #2
Tainted's Avatar
Personally id go for the mast. They look killer
Tainted is offline   Reply With Quote
Old 04-02-2012, 02:30 PM   #3
Allpro
ws602 is offline   Reply With Quote
Old 04-02-2012, 03:15 PM   #4
I run a small bore ls7 head on mine.
ZGLASS is offline   Reply With Quote
Old 04-02-2012, 03:56 PM   #5
You say your building a 402 so you only have a 4"bore right? Better check those Trick Flow heads for their minimum bore required.I believe the 235's require a 4.03" bore and the 245's bigger yet.Those heads have bigger valves so it might be a problem but it could be that they fit but aren't recommended because of valve schrouding.A ls7 type head would be good but it will have to be a small bore version like zglass has.
oldguy99Z is offline   Reply With Quote
Old 04-02-2012, 05:13 PM   #6
silver2010's Avatar
I run the Mast black label heads. My bore is 4.125 so you need the small bore version. Check out Mastmotorsports.com
silver2010 is offline   Reply With Quote
Old 04-02-2012, 05:46 PM   #7
djfury05's Avatar
small bore Mast or Allpros
djfury05 is offline   Reply With Quote
Old 04-02-2012, 06:13 PM   #8
litle88's Avatar
Can't beat ported Ls3's for the money. LPE has theirs for 1500 shipped and assembled lol. Hard to pass that up.
litle88 is offline   Reply With Quote
Old 04-02-2012, 06:50 PM   #9
RoidedSS's Avatar
if price isn't an option, I'd agree with djfury, mast or allpro
RoidedSS is offline   Reply With Quote
Old 04-02-2012, 07:32 PM   #10
scphilli's Avatar
What style fast 102 do you have (LS1/LS2, LS3, or LS7)? You'll want a set of heads that match or you'll be needing a new intake.
scphilli is offline   Reply With Quote
Old 04-02-2012, 11:05 PM   #11
The1N_only's Avatar
Bang for the buck I would say TFS 245's and just guessing... The would best fit your application.
The1N_only is offline   Reply With Quote
Old 04-03-2012, 12:09 AM   #12
I have a cathedral port 102 ported by tony mamo, ill have it portmatched to a set of heads i get if i stay cathedral...so i thought MAST and ALLPRO were the same??? so how are mast better than trickflow i called mast once and asked for their flow numbers and looked on TEA website and the trickflows flowed better (they say)....
what mast would i get what are they called?
Old 04-03-2012, 12:59 AM   #13
I would not get the mast. There are a few issues that you have to address that IMO should not need to be addressed.
My vote so far and every time is Trick Flow. Although a 245 head would be a bit large, the 225 or 235 would be the best bet. If you want even more out of them, I am sure TEA could spruce them up a bit more for you.
gectek is offline   Reply With Quote
Old 04-03-2012, 06:18 AM   #14
i have the TFS 245 on a 427 love them for a 402 i would stay 235 if boosted maybe 245 or reving really high
BigRich954RR is offline   Reply With Quote
Old 04-03-2012, 07:56 AM   #15
Allpro
EDS ZO6 is offline   Reply With Quote
Old 04-03-2012, 09:39 AM   #16
What "issues" need to be addressed?
Old 04-03-2012, 11:41 AM   #17
KILLERARMY's Avatar
WCCH All Pro
KILLERARMY is offline   Reply With Quote
Old 04-03-2012, 11:57 AM   #18
I just called allpro and there "DRAGPORT" heads is what we discussed
they are flowing 355 at .600
and on exhaust 248 at .600
they have a 2.125 intake valve and a 1.625 exhaust
then i looked at the TEA Trickflow 235s and they are flowing
343 intake
276 exhaust with 2.080 intake and 1.600 exhaust valves
it looks like the trickflows are smaller valves and flowing around the same numbers on intake and better on exhaust...with a smaller valve which would probably be better on a 4in. bore
Old 04-03-2012, 10:15 PM   #19
CAMSTER's Avatar
Default Mast mediun bore....
Are for ls2 the small bores are for ls1...
Designed for any new Gen IV short-block with 4.000" bore or larger
The 6-Bolt design is compatible with GM LSX and World LSX blocks
Accepts Gen IV LS3 valvetrain and intake manifolds.
Uses a 2.165" intake valve and 1.600" exhaust valve
Has a 256cc intake port
Has a 69cc combustion chamber standard
Has a deck thickness of .750"
Each Mast Black Label cylinder head assembly includes:
A fully CNC machined Mast Black Label aluminum cylinder head
Mast nitrided & micro finished .650 lift beehive valve spring
Then get the hollow steam SS intakes upgrade, get the 6 bolts head even if you are not using them, cost is the same, and are further re-enforced, by the added busses, and have better resale value, then if you still have the block outside, have some one weld the receiver busses, on the out side of the block to bolt the 5th...you'l be glad you did..
CAMSTER is offline   Reply With Quote
Old 04-04-2012, 08:11 PM   #20
Quote:
Quite a bit longer spark plugs wires, like going to at least the truck style MSDs. Then there is the problem of their holes in the heads that line up with the stands on the intakes are too small and you have to grind all the stands off save for the 2 metal ones. They work.
There are a few others, but those are the biggest 2.
Related Topics
Thread Thread Starter Forum Replies Last Post
help me with choosing great heads for FI C Murda Forced Induction 11 10-02-2014 07:27 PM
How far can you take trickflow cnc225s? SStressin Generation III Internal Engine 5 06-29-2014 12:34 AM
Mast 235 vs trickflow 235 00blacka4 Generation IV Internal Engine 11 04-30-2012 11:03 AM
Trickflow 235's and 4.005" bore? LSxPwrDZ Generation III Internal Engine 8 04-24-2009 10:22 PM
Trickflow 235 cc 2002gt Generation IV Internal Engine 16 02-25-2008 01:13 AM
Tags
black, bore, camsters, engine, flow, heads, label, ls1tech, ls2, ls3, ls7, mast, small, stroked, trick
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
