Nice cam from Pat G
Nice cam from Pat G
08Z06
run 69 is 32* overlap cam, Marcella intake
run 72 is same cam , Hogan crossram with small runners
run 79 is Pat spec 22* overlap cam with new Hogan intake
driveability is very nice with the new cam and pleased that power is increased all the way to 6300 where the bigger cam finally equals.
I will certainly use Pat to spec any cams for new builds
Huh! Where do u see 3 cams? The progression should be obvious-looking to keep power but improve driveability. First manifold was not re-dynoed after cam change because I already knew it had too short of intake runners for my goal, second manifold was too small.
care to share some cam specs?
maybe through pm if needed?
I just got my ls7 motor on the dyno and was surprised how early it peaked.. Also looking at yours even the highest revving cams don't pull past 7k.
Sent some basic info but it would be best to give Pat your details and get a cam spec'd that optimizes your combo. I should have done that earlier.
