4 bolt too 6 bolt head?
Can you convert a lq9 block too use 6 bolt head studs… the reason I'm asking is I got a 408 I plan on spraying a 3 stage set up spraying any where from a 350-450 hit
Iron doesnt weld very easy. Ive seen alot of iron block welding for leaks and repairs. but never for adding bolt holes which would be have a pulling force on them.
Not say it cant be done ive just never seen it, I would guess the mount would pull off from heat cycles and force.
If some one know for sure about this id like to know to increase my knowledge base. but looking for people that have done it,
Iron welds just as well as aluminum...it just has to be heated up before welding to keep it from becoming brittle.
