427ci LS2 Sleeved, 4 barrel TB, port FI, NA, dry sump, engine build.
Old 05-11-2014, 11:15 PM
  #121
CarlC's Avatar
Dale, if you are ever looking to re-do the air cleaner an aluminum cake pan makes for a great housing to mount the base to. On the previous carb'ed 406 in the Camaro it worked quite well and was easy to work with. Riveting the base to the cake pan worked fine, just put the rivets in the recess of the air cleaner seal.
Old 08-03-2014, 04:31 PM
  #122
Mikelly's Avatar
I cant tell you how much I have used this project build thread to help me solve many of my own issues. So few aftermarket builds with dry sump systems have been documented, so I am limited in the help out there... Running the Nutter Racing Drysump on my Datsun Zcar LS403 build and trying to make it all work properly has been a challenge in the small S30 chassis. Getting there though!
Mike
Quick Reply: 427ci LS2 Sleeved, 4 barrel TB, port FI, NA, dry sump, engine build.
