lq9 with prc 237 heads
I have a freshly rebuilt stock 2003 lq9. I'm looking to do a high compression all motor street car. Car will probably see the track twice a year. I was wonder where that would put me around compression wise and if i should get them milled and to what? After my heads are chosen (pretty sure it'll be these but im open to ideas) ill be having a cam specd out by predator. here is a list of what the car has:
102 fast set up, tsp 100mm maf, 104mm lid, full exhaust with bolt ons, and converter.
Not worried too much about hp numbers but would like to see a low 11 high 10 second pass out of it. Thanks a lot
Yeah tfs are definitely something I have been considering. Ive just seen so many of these applications I want to do something a little different. Seen a couple of these set ups and they run pretty decent. we shall see I'm still waiting on a few other parts. And litle, u ever go to strats or anywhere like that? I'm from the st Charles area
LS1Tech Premium Sponsor
What chamber size do you need? Also do you plan on cutting the pistons? this will better tell us your p/v constraints so we can select the best possible head for getting you compression & flow!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
