diamond piston part # for 6.0L LQ4 pistons?
I am wanting to make sure I get the correct pistons. I have an LQ4 that is bored .30 over. I need a piston with valve reliefs. I was told diamond has them. I have a set of ls3 heads I will be putting on the 6.0L so I want to make sure they have reliefs in the pistons to avoid PTV.
is this a correct part number before I order them?
Diamond part # 11515
If so, it says my compression ratio is going to be 8.9 with the 70cc ls3 heads. That is way to low I think. Thoughts?
