LS2 in Burned out Trailblazer SS
Old 06-20-2012, 03:32 PM
LSx '73 Nova's Avatar
Default LS2 in Burned out Trailblazer SS
We were searching the junkyard today for Nova parts and came across a Trailblazer SS that had caught fire ,but the engine was still in the car. i was wondering if the engine would be safe to take and rebuild and use in our Nova. Can somebody help me out?
We are mostly after the heads but if the engine would be okay to build then we thought about buying it
Old 06-20-2012, 03:42 PM
ramairws6's Avatar
I woudn't touch that with a 10 foot pole....
Old 06-20-2012, 03:45 PM
For what reason????
Old 06-20-2012, 04:01 PM
Tainted's Avatar
Dude that thing is done. Everything has heat stress, melted sensors r fucked. Dont go any further than just looking at it.
Old 06-20-2012, 04:06 PM
i couldn't even take the 243 heads?
Old 06-20-2012, 04:11 PM
TypeSL2's Avatar
That looks like one helluva fire man. I would be a bit skeptical about using anything from it. Maybe the bottom might still be good though. May be worth the purchase just to disassemble and assess from there.
James
Old 06-20-2012, 04:19 PM
LS1MCSS's Avatar
Due to the fact that NONE of the aluminum parts on the outside of the motor are melted, the inside will be fine with some work. The heads will need a valve job, new seals and get new springs while your at it. None of the plastic **** is fit to use but the internals of the motor won't be hurt.
Old 06-20-2012, 04:27 PM
Tainted's Avatar
Bullshit. Look at everything melted on top of the heads. Imagine that intake melting and going down the ports. Not including everything else thats melted inside the block like knock sensors, valley cover parts, cam crank sensors, Rubber seals etc. That **** is toast period.
If you wanna **** money away on buying a pile of burnt *** paper weights I can sell you some of those!
Old 06-20-2012, 04:35 PM
Plastic melts at a much lower temp than aluminum and last time I checked plastic doesn't adhere to aluminum. We already chipped at the plastic and it comes off. We can replace seals and sensors. I saw no evidence of fire in the engine bay just heat related stuff. It was a fire in the interior.
Old 06-20-2012, 04:37 PM
got milk??'s Avatar
Looks like everything metal is in good shape. If the deals right I would jump on it as a spare engine to rebuild. LS2 blocks arn't real cheap or a dime a dozen either. I say give it a shot if the price is right.
Old 06-20-2012, 04:40 PM
86cutlass350's Avatar
heads block nd rotator are fine id put money on it, where is it located? if its close to me id buy it if it was cheep.
Old 06-20-2012, 04:44 PM
It's in Arizona, maybe the 112 degree heat melted the intake lol
vetteboy99's Avatar
Intake would have melted into the valves.
Old 06-20-2012, 04:49 PM
402GOAT's Avatar
i would imagine the temps it reached internally due to the fire would be know more than what it sees during normal running of a combustion engine. the damage would be on the outside of the block. for the right price, id be all over it
Old 06-20-2012, 04:50 PM
Tainted's Avatar
well good luck. you can get a set of 243 heads all day long for $400 that you dont have to put any work into and it aint been in a damn fire.
Old 06-20-2012, 04:55 PM
For $150 for the pair plus the cost of a valve job would be around $450 total. It's still a savings of $350. GMPP sells them for $378 each brand new.
Old 06-20-2012, 05:05 PM
82cetuner's Avatar
id offer 100 bucks for the engine. take it home and dissasemble it, as long as the block, rods, crank and pistons check out at a machine shop have them rebuild it for about 900 bucks. and you can melt the plastic back out of the heads and off the block for that matter its no big deal once you tear it all apart and clean it all up its worth 100 bucks to check it out
Old 06-20-2012, 08:16 PM
ramairws6's Avatar
Hahahaha! What a waste of time and money imo. Goodluck and have fun with all the issues that will pop up down the road...
Old 06-20-2012, 11:02 PM
Received 3,368 Likes on 2,085 Posts
Interior fire? Lol. Melted the rubber out of the damper. If it hasn't been covered, it's full of rainwater. Walk away, bro. I wouldn't haul it home if it was free. I had an opportunity to buy an ls3 out of a camaro that had an interior fire, with under 10k, and it Had a melted intake, and coils. That blazer your looking at has been very, very hot.
Old 06-21-2012, 12:07 AM
bww3588's Avatar
Nonsense. If the hard parts are good, and you can get it for a decent price, go for it. I pulled an ls1 out of a camaro that had an engine fire and spread all the way to the rear bumper before it was put out.
The fire was so hot the valve covers started to melt. I drained 8 gallons of water out of the engine after I pulled it. Guess what? Everything south of the valve covers was fine. Had the heads milled and the bores honed and it's still running 4 years later.
Quick Reply: LS2 in Burned out Trailblazer SS
