Custom ITB setup / LS3 inlet port size widht/height ? - LS1TECH
Thread Tools Search this Thread
Old 06-28-2012, 09:38 AM   #1
Default Custom ITB setup / LS3 inlet port size widht/height ?
Could anyone measure what´s the size of LS3 inlet port, widht/height, and how far ports are from each other (center point)?
Wouldn´t want to take of my intake manifold for this wondering...
I have broken BMW M5 S62 V8 engine in my garage and it has 50mm ITB setup from standard. Couldn´t help of thinking if it should be fitted to my LS3, first problem is that in those throtle bodies inlet port shape is just the opposite than in LS3 heads wider vs height, but that could be solved with adapters. I have standalone engine management, so eletrical issues is no problem.
Mikko is offline   Reply With Quote
Old 06-28-2012, 10:11 AM   #2
redtan's Avatar
Good idea, but seeing pics of the M5 heads not gonna happen unless you make a custom lower manifold to match up the the M5 one at one end and the LS3 heads on the other end.
redtan is offline   Reply With Quote
Old 06-28-2012, 11:02 AM   #3
Quote:
This is just what i had in mind, not a problem. 2-3 inc twist shape tubes between flanges.
But the size, So throtlee bodies are 50mm which should be enough, inlet on M5 head is 2" width, 1" height, and throtle bodies ofcourse match in those, you can port those little but not much, maybe to size 2 1/4 x 1 1/4, seems quite small comparing to LS3 ports by the pics i´ve seen.
Custom ITB setup / LS3 inlet port size widht/height ?-img_0902.jpg   Custom ITB setup / LS3 inlet port size widht/height ?-img_0903.jpg
Old 06-29-2012, 12:15 AM   #4
Bump for size info
Old 07-16-2012, 12:37 AM   #5
Still need this info.
Old 07-16-2012, 07:33 PM   #6
96 Comp T/A's Avatar
Well, the bore centers are 4.4 inches apart, and since the ports seem to be mirrored hole to hole, I would try that number on for size.
96 Comp T/A is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
LS1 into a Porsche 996 geeky Generation III Internal Engine 0 12-22-2016 09:08 PM
FS: Harrop LS3 Hurricane ITB Manifold (DBW) efnfast Parts Classifieds 9 09-09-2016 01:25 AM
Looking to build an LS1 based engine. Have several questions, need advice please. chrishuynh Generation III Internal Engine 86 06-08-2016 05:14 PM
Dominator or GMPP crate engine ECU? efnfast PCM Diagnostics & Tuning 4 10-09-2015 10:44 PM
ITB's for LS engines Beard Advanced Engineering Tech 68 07-24-2011 03:25 PM
Tags
adapter, bmw, custom, dimension, engine, inlet, intake, itb, ls1, ls3, ls6, m5, manifold, match, port, setup, size
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
