na ls7 build... is sleeving needed
Old 07-09-2012, 08:32 PM
baggins's Avatar
Default na ls7 build... is sleeving needed
So I have a standard bore ls7 that I just picked up. Its got some mystery flat top pistons, lunati pro billet rods, and a lunati crank. My question is is it necessary to re sleeve the block? I plan on maybe running g a 200-250 shot. This is a street driven six speed car.
Thanks for any input
Old 07-10-2012, 08:12 AM
redtan's Avatar
Not unless the pistons you have are a much bigger size than can be accepted by the current bore.
Old 07-10-2012, 09:23 AM
baggins's Avatar
Pistons are 4.125... ill post pics later
Old 07-10-2012, 09:50 AM
ERL Performance's Avatar
Not saying for sure that you can't do it without sleeving but I have quite a few LS7 cores here with cracked cylinders due to higher cylinder pressure and OEM cast iron sleeves.
Those sleeves were not designed for a 200 to 250 shot of nitrous. I know people will think I'm biased because we sleeve but I thought I would respond to this because I see way to many cracked blocks because of this.
Good luck with your build!
Old 07-10-2012, 09:54 AM
ramairws6's Avatar
I would agree 100% but thats just IMO and i'm sure we'll hear otherwise...
Old 07-10-2012, 10:04 AM
Super Moderator
Reckless's Avatar
Agree with ERL. I would not push a stock LS7 past about 750 flywheel
87silverbullet's Avatar
I'm with ERL. The sleeves are prone to cracking. If it was just N/A I would leave it. With the spray I say sleeve it
Old 07-10-2012, 10:42 AM
djfury05's Avatar
I don't like hearing this since I was planning 150-200 shot
Old 07-10-2012, 11:52 AM
6D9 Matt's Avatar
NA you should be fine, but yes I would recommend resleeving with any kind of nitrous/blower/turbo.
Old 07-10-2012, 11:56 AM
COPO9560's Avatar
Building an LS7 based engine is not cheap - why cut corners now. If you can afford new dry sleeves, it would provide a lot of insurance for the future. Last thing you want is to have to build this engine twice.
Old 07-10-2012, 09:13 PM
baggins's Avatar
So I bought a disassembled ls7 shortblock below are the pictures of the pistons. I am having a hard time getting info on brand and specs. The numbers on the skirt are
809ts & 28583
Thanks, Nick
Old 07-10-2012, 09:19 PM
Shelby7's Avatar
Darton Wet sleeve it and have some piece of mind.
Old 07-10-2012, 09:38 PM
baggins's Avatar
Not interested in putting $3k into this block.... if I stay NA will I have any issues
Old 07-11-2012, 12:45 AM
delphigto's Avatar
You could sell the ls7 block and buy a resleeved one for close to the same money and have a better block.
Old 07-11-2012, 05:09 AM
baggins's Avatar
Whats an ls7 block worth?
Old 07-11-2012, 07:16 AM
ramairws6's Avatar
^^^ What he said....
Old 07-11-2012, 08:13 AM
ss454327's Avatar
TSP sells the LS7 block for $2899.
Old 07-11-2012, 09:25 AM
djfury05's Avatar
how bout a used LS7 block what's that worth?
Old 07-11-2012, 09:29 AM
baggins's Avatar
Any ideas on the pistons?
Old 07-11-2012, 08:31 PM
MrEracer's Avatar
They look like Diamond pistons. I'll give you $1000 for your block.
MrE
Quick Reply: na ls7 build... is sleeving needed
