LS3 Results - Any Guesses?
Hello all! I'm new here, although I've had my 02 Z06 for a couple of years. I'm going back to NA, found a really nice Katech forged LS3 shortblock to drop in in place of the LS6. To keep this fun, I'm going to see who has the closest guess on WHP results on a Superflow dyno. Car will be professionally tuned after build so I should get accurate numbers when I pick up the car next week.
Specs:
-LS3 shortblock built by Katech, all forged/balanced internals. Equipped with Katech oil squirters under the piston to keep things cool.
-Stock 243 heads, stock LS6 intake (I know, I know. Leaving alot on the table. Going to better head/intake is a winter project...) Then again these heads shouldn't have the oiling issues of the LS3 heads.
-Comp Cams XE-R 224/232 cam, 918 springs
-Vararam
-LG Street headers, high flow cats, Corsa Touring catback
-McLeod RST Dual-disc clutch, 14lb lightweight aluminum billet flywheel
-RPM Stage IV MN12 trans. Stock gearing.
-Stock rear end, 3.42 ratio.
-315 Michelin PS2 in rear.
So any guesses on final numbers?
Also, anybody out there running a similar setup?
THANKS!
Specs:
-Vararam
THANKS!
I would diffently pick up at least a stock set of Ls3 heads an intake. The Ls6 is going to really choke that motor. I had a bone stock Ls3 in my 2000 Z28 an made 465rwhp an 430ish tq (can't remember the exact TQ).
I just did a LS3 swap in a C5 two weeks ago with ported LSA heads an Lingenfelter GT-11 cam, Borla headers an it made 551rwhp an 499TQ.
1-time
2-money
I'm in Germany as well so LS3 heads are a bit thin on the ground and I want the car done next week. It's been down hard for over a month in the summer in prime driving weather so I'm focused on getting it up and running, it's in storage over the winter so I can do some research and shop around for exactly what I want.
Those are great numbers you made for a NA motor with LSA heads, I'd be happy with power like that. Part of the reason I went with the LS3 is so I can use a set of the big-bore heads down the road. I'll be selling off the 243/LS6 intake combo as well so should make back some of the cost.
Anyway- back to the original question. Numbers?
Plus the torque don't add up. LS3 strokers don't make that much torque, let alone a stock cube one. That dyno is broken for sure. Here is a quote from a member of his LS3 418.
01 camaro
Ls3 416
Tea tfs 245
Eps 243 251 .628 .632 113+2
11.2 compression
Fast 102/102
1 7/8 LTs offroad xpipe
M6 with 10bolt
UD pulley
Gz vacuum pump(10inches)
Stock rockers
549rwhp 479 rwtrq
Overall I'm happy with it. Its night and day difference from the h/c ls1. Dyno was on a dyno jet at eps through full exhaust with only 120 miles on engine. I will dyno again after a few thousand miles to see how much I gain. I can also pull more vacuum is nessacery. Drivability is pretty Nice also. Thanks Geoff for all the time and phone calls! Ill post dyno sheet soon.
Ls3 416
Tea tfs 245
11.2 compression
Fast 102/102
M6 with 10bolt
UD pulley
Stock rockers
549rwhp 479 rwtrq
Here is the thread.
https://ls1tech.com/forums/dynamomet...5-eps-cam.html
OK you're the first one to make an actual guess rather than just tell me to get LS3 heads or spout inflated numbers from a stock LS3. We'll know mid-week how close you got. I'm hoping for a bit more but will just be happy to have the car back on the road while the sun is still shining.
I'll guess 440 RWHP if you use a competent tuner. I really enjoyed the Comp Cams XE-R 224/232 cam; I ran it in my LS2, but never had that set-up dyno'd. I can't wait to see your results.
I've found some clips of cars running with that cam, I really like the sound and feel of it. I want some chop but nothing crazy.
The short block was built by Katech for a GT4 car, it's forged with all the tricks so it should be a real solid bottom end for a high-winding street motor. I'm hoping that not even I can kill this one.
I'll keep you posted on results.
My tuner is not going to be the limiting factor. I have faith in his abilities.
Keep 'em coming!
I'm in at 432. Sounds like you have a great tuner.
Thanks man! Yeah I've got a solid base to build on. Will watch the forums for LS3 heads/intake for sale. Will have LS6 intake/243 heads up for sale at the same time.
BTW- *NICE* build thread on that 69 Camaro. That thing really hauls the mail.
