LS2 Block which Valley Pan (PICS)
Old 08-01-2012, 07:09 AM
McAllister513's Avatar
Default LS2 Block which Valley Pan (PICS)
Ok I picked a good aluminum LS2 block that I have took to the machine shop to be honed and cleaned up. I'm in the process of ordering parts to get this build going and wondering which valley pan I should use. The part number says the block was a 05 model but I do not know what it came out of. It does have to holes in the valley area like the L92 blocks and such. I have read that I can use the LS3 valley pan Part #12599296 is this true.
Old 08-01-2012, 08:10 AM
Gray86hatch's Avatar
Ls3 cover will work
Drill and tap the towers for 1/8 pipe plugs
Tim
Old 08-01-2012, 09:26 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
LS2 and LS3 valley covers are identical except for the fitting that breathing fitting that comes out the front....the fittings are in the same spot, but with a different style fitting on each.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Quick Reply: LS2 Block which Valley Pan (PICS)
