lsa heads with iron 370 what do i need for the conversion?
Why LSAs vs. LS3s? Alot of boost in your future?
You need LSA rocker arms for intake and rocker stands. The LSA heads have a flow director in the intake bowl that will really restrict the flow in a normally aspirated application. Plan on doing or getting some port work done on them if your not going FI on your build.
I just did a 370/LSA head swap in my 99 Camaro. You will have to extend the map sensor harness because the sensor is located on the front of the intake on a ls3 manifold as opposed to the rear on a ls1/6 manifold.
