Windage tray question
I am having my 408 built to put in my 02 f body. I have a question on which windage tray do i need to run, i will be using my stock ls1 oil pan, should i use the ls1 windage tray and will it clear the stroke.
Im putting in the improved racing baffle and it's direct bolt in. I pm'd Carry over at mast and they are $80 and waiting to hear more about how it installs and would work the exact same on a 408. Also if you want to utilize both oil pump pickup tube bolt holes BRP hot rod sells on for ls swaps for 25. Under g-body section.
