LS3 blower cam specs
Old 08-23-2012, 12:13 PM
ultradriver10000's Avatar
Default LS3 blower cam specs
What would be a good LS3 blower cam? Its for a G8 Gxp so the car is a little heavy. Car has a maggie 2300 right now and is putting down 460/415 with 6psi and the guy is unhappy with the results. I'm trying to help him make some good upgrades and I think a cam and 8psi will do the trick.
What do you guys think about say a 215/228 .605/.615 on ll6 lsa or maybe the same thing on 224/232?
What would you suggest?
A local shop is suggesting a 228/232 .588/.595 on 114lsa....
Old 08-23-2012, 03:35 PM
Sales@Tick's Avatar
226/234 .605"/.612" 114+3 lxl/lxl
Old 08-24-2012, 09:45 AM
cool thanks! I didn't think their suggest cam was a good choice at all
Old 08-24-2012, 09:14 PM
red 454's Avatar
im running a comp 224x228 x581 lift 0n 114 lsa
with the harrop 2300 0n 10 psi with long tubes and duel 3" pipes
and OTR lid
doing 410 RWKW in 35.c temp days
Old 08-25-2012, 01:04 PM
Why so tight with square port heads? Does a blower change the separation that much?
Old 08-25-2012, 07:36 PM
Sales@Tick's Avatar
Man I totally missed that this was for a LS3. End of the day and I was struggling lol.
That would change things around a good bit.
226/238 .605"/.595" 116+5 LXL/Extreme Marine High Lift
Old 08-25-2012, 09:43 PM
Oh4GTO's Avatar
Before just throwing more performance parts at it, you should double check the car and tune. That is super low on power, there is something else wrong.
Old 08-25-2012, 11:21 PM
Sales@Tick's Avatar
I agree the car is low on power, but it could be due to just too little boost.
The OP did reference going to 8psi so I would assume(that can hurt you sometimes) that it would be far less than that now.
Old 08-28-2012, 09:31 AM
Correct car is currently at 6psi....whats a safe bet on a stock short block? 10psi?
Old 08-28-2012, 01:58 PM
Sales@Tick's Avatar
I wouldn't be afraid to run it at 10psi at all with a good tune.
Old 08-28-2012, 06:40 PM
red 454's Avatar
mines been on 10 psi for 3 years done about 30,000 km
Old 08-28-2012, 06:42 PM
Bo White's Avatar
http://www.compcams.com/Company/CC/c...csid=1419&sb=0
Quick Reply: LS3 blower cam specs
