6.2 AFR 225cc G6x3 or MS4
Old 08-24-2012, 12:25 AM
blackLS1m6's Avatar
Default 6.2 AFR 225cc G6x3 or MS4
Putting together a 6.2L stock bottom end with AFR 225cc heads that have been milled to achieve a 66 cc combustion chamber. I know a custom cam would be best but I'm using what I have for now and can't decide if I should put in the MS4 or the G6x3 both an a 112 LSA. It's going into an 01ss 6 speed S60 with a 4.30 gear.
Old 08-24-2012, 05:38 PM
Oh4GTO's Avatar
I had the same shortblock and heads with a 12:1 compression. I went with the StreetSweeper from Flowtech because it is a proven cam. I broke 500 RWHP on a new engine with cheap headers. There was power everywhere and very linear.
Old 08-24-2012, 06:01 PM
87silverbullet's Avatar
I say the g6x3
Old 08-25-2012, 05:41 AM
00BlackSS's Avatar
vote for g6
Old 08-25-2012, 10:10 AM
blackLS1m6's Avatar
Wow solid numbers! I think I should be able to hit 500rwhp with my setup. I'm leaning towards the g6 too seems to perform very well with cathedral or ls3 heads
Old 08-25-2012, 11:14 AM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
Are you certain you will have clearance for cams like that?
Old 08-25-2012, 11:17 AM
LS1TECH Sponsor
Ryne @ CMS's Avatar
i doubt he has thought that far ahead lol...
Old 08-25-2012, 11:35 AM
While not certain if the Op will be ok, the g6x3 clears PTV on a stock LS3. That's a 70 cc chamber vs. a 66 cc chamber. I wouldn't think only 4 cc's on the chamber would affect the PTV? Isn't it like .004 of and inch per cc? If that's the case then yeah PTV might be an issue.
He still could run a thicker gasket and solve that issue if he runs across it.
Old 08-25-2012, 12:51 PM
batboy's Avatar
More like .006" per cc.
Old 08-25-2012, 01:04 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
i think checking piston to valve to going to be mandatory, in addition throwing a thicker gasket at it while increasing quench is not a good idea either.... i would rather flycut before doing that..
Old 08-25-2012, 06:45 PM
blackLS1m6's Avatar
Sorry to put an end to your comedy show, but I am flycutting regardless if it clears or not. Even if it does clear its too close for comfort. All I asked is an opinion from someone who might have done a set up like mine. Both cams were acquired because the price was right, not because Im a nut swinger on cams with a special name. Maybe I'll test both.
Pete
Old 08-26-2012, 07:18 AM
OrangeChevyII on here has a 2010 LS3 camaro and has been 10.20 with that cam and spray and no PTV issues.
Were not talking much here on gasket thickness. Also, its somewhat a trade off, big chamber-thin gasket vs small chamber-thick gasket.
Old 08-26-2012, 07:21 AM
Pete
Are you putting together an L92 or LS3? Reason I ask because L92 pistons come with reliefs in them and didn't know which one you were building and it would help in this situation.
Old 08-26-2012, 08:34 AM
blackLS1m6's Avatar
Thanks 87silverbullet, Its an l92 shortblock and I will be checking ptv just to make sure I have enough with the factory reliefs. It's a six speed with nitrous too. I have the ms4 in my ls1 now, how much it clears by I don't know it's a chance i took, I've heard both clearing without reliefs but I'm sure it's not enough clearance to be on the safe side.
Old 08-27-2012, 09:15 AM
It should be ok. Both cams were designed to clear in stock engines. Still check it no matter what.
Quick Reply: 6.2 AFR 225cc G6x3 or MS4
