L76 swap, which timing cover?
Old 08-30-2012, 09:56 PM
work in progress's Avatar
Default L76 swap, which timing cover?
This one- http://www.ebay.com/itm/LS2-LS3-LS6-...#ht_1655wt_842
OR
This one- http://www.ebay.com/itm/LS2-LS3-LS6-...sories&vxp=mtr
Or are they one in the same, one just without the cam sensor?
I have seen a couple of different covers and just want to make double sure I order the right one.
Old 08-30-2012, 10:04 PM
Sales1@Texas-speed's Avatar
I read through both descriptions and it appears to be the same part with the same parts included. Unless I misread something these are both identical.
Old 08-30-2012, 10:05 PM
Never mind I found it, and a better price than Ebay.
http://sdparts.com/details/gm-factor...arts/k12600325
Old 08-30-2012, 10:07 PM
Oops, I meant to post up 2 different links.
Old 08-30-2012, 10:09 PM
No worries let us know if there is anything we can help you with.
Old 08-31-2012, 01:23 PM
1lejohn's Avatar
Thats the one i used SDPC is hard to beat for there conversions. You'll need a extension harness from racetronix to connect to the LS1 harness. I used a nice little stainless tubing clamp to keep it away from the balancer and belt. Its bolted to the timing cover.
Quick Reply: L76 swap, which timing cover?
