ls3 cam in 5.3
LS1TECH Sponsor
The LS3 cam is essentially a LS1/LS2 Z06 Vette cam.... with the exception of it being a single bolt version.
It does not have the cam position sensor at the rear of the cam like the early 5.3.
If your 5.3 is 07 & newer it should work as you already have a single bolt cam.
It will not fit early 5.3's
I have a 2011 Camaro cam, bolt & gear with 12miles on it if interested.
