Huge sale from granatelli motor sports
Old 09-07-2012, 03:12 PM
granatelli sales's Avatar
Talking Huge sale from granatelli motor sports
GRANATELLI MOTOR SPORTS IS HAVING A SALE
WE HAVE PART FOR 1993-2013 CAMAROS
Lower Adjustable Panhard Rod
Rear Lower Control Arms
G-Load Brace
F-Body Rear Lower Control Arm Relocation Brackets
MAF Sensor
Valve Covers
LS1 & LS6 Cars Coil-Near-Plug Conn Kit
2010-2013 Camaro Twin Turbo Kit
2010 - 2013 Camaro 1G Suspension Bracing Package
2010 - 2013 Camaro LS2 LS3 L99 Cat Back Exhaust
2010 - 2011 Camaro Performance Stainless Steel Headers
2005-2013 GM LS2, LS3, LS7, LS9, LSA, L92, L99, L76 80KV Coil Pack
2010-2013 Camaro Cold Air Intake system
2010-2013 Camaro Pro Stock Look Wing
2010 - 2013 Camaro LS2 LS3 L99 Axle Back Exhaust
2005-2013 LS2/LS7/LS3 Cars Coil-Near-Plug Conn Kit
CALL 805-486-6644 SO YOU CAN GET A GREAT DEAL ON THE BEST PARTS
Old 09-12-2012, 03:00 PM
Ends soon Get your great parts TODAY
Old 09-12-2012, 04:50 PM
Jontall's Avatar
Are the 2005-2012 GM LS2/LS7/LS3 Cars Coil-Near-Plug Conn Kit (Hi Temp Red wires) on sale? Those are what I want and they never go on sale.
Old 09-12-2012, 05:19 PM
PM sent
Old 09-14-2012, 02:32 PM
Axel back exhaust for 5th gen camaro only $299 get your great sounding exhaust today
Old 09-19-2012, 03:40 PM
Old 09-19-2012, 05:57 PM
ALSO
if anyone is in the ventura county, california area with a V6 gen 5 camaro and would like an AWESOME deal on an axleback kit, please contact us. we've developed an axleback for the v6's but need a vehicle for testing / fitment.
we'd need your car for a couple of hours, but the axleback kit would be offered at a discounted price and ALL LABOR for install we'd throw in FREE.
if you want to jump on this deal, contact me via p.m. or call in 805-486-6644!! ASK FOR JASSPER
Old 09-19-2012, 07:58 PM
blackmaverick's Avatar
awesome stuff
Old 09-21-2012, 01:47 PM
Old 10-03-2012, 04:11 PM
Discount on everything tell me what you are interested in and ill give you a price shipped to your door
Old 10-03-2012, 05:16 PM
blackonblacksls's Avatar
Pro stock wing shipped to 77012
Old 10-12-2012, 11:31 AM
pm sent
Old 10-24-2012, 01:22 PM
DEAL OF THE WEEK 10/22- 10/26
$175
Shipping not included
Fits 2005-2013 GM LS2/LS7/LS3 Cars
Direct OEM replacement, exceeds OEM specifications, OBD-II computer safe
0 Ohm resistance
Patented* design
Solid stainless connector cable with stainless snap lock spark plug connectors, unique EMI/RMI protection ring
The only true solid stainless steel core wire that works with today’s computer dependant engine and all race cars
No RFI / EMI issues – works with any fuel injection / No stereo noise
Increase power to the spark plug up to 400% over stock
Improves mileage and throttle response
High temperature silicone boots, 8MM jacket with fiberglass-reinforced
braid with fire sleeves resists temperatures up to 1200 degrees f
Ideal for use with aftermarket headers and turbocharger systems
Includes all necessary hardware
* Granatelli O ohm wires are patent protected by United States Patent number 7,185,622. This patent covers our unique method of producing ignition wires of extremely low resistance while maintaining very high noise suppression. The benefit of this invention is that full electrical energy from the ignition source is transmitted to the spark plug. The end result of the application of this method is increased horsepower, torque and fuel economy.
Old 11-09-2012, 05:22 PM
STD Height LS2/L98/LS3/LS7 w/ Coil Mounts
$600
ONLY 2 LEFT
Our standard height range of LS Series engine valve covers are designed with the street performance enthusiast in mind. They increase the aesthetic appeal of the LS engine ten-fold while still offering both the factory style breather option, as well as adequate material at the front and the back of the covers to add -6 fittings for more serious street engines.
Factory style baffled breather
Front and rear bosses for adding larger breather fittings
Integral bosses for mounting ignition coils directly to cover
O-ring seal to cylinder head
CNC machined oil cap with o-ring seal
Supplied with stainless mounting hardware
Old 12-14-2012, 03:14 PM
Granatelli Motor Sports is having sale on All exhaust and Axle back systems
This is on our Twin Turbo System
In this video, we compare Stock, our Touring, and our Sport Exhaust (PN: 500067 [for touring], 500067-S [for sport]).
V6 axle back
In this video we go over the install of our axle-back kit for the Gen5 V6 Camaro (PN: 500067-6 / 500067-S6). We also provide a sound byte of our Sport System (PN: 500067-S6) installed on a customer vehicle.
Stock v8 with Granatelli Axel Back
Part# 500063-S LS3 & L99 Catback 2.5" Exhaust System, 304 Stainless, 4" Tips, Sport System
Please Note: The clip was made using a stock vehicle with catalytic converters.
FOR ALL SYSTEM $345
Old 10-03-2013, 09:38 AM
csaunders16's Avatar
Default csaunders16
g load brace 2010 ss camaro #500075
Old 10-04-2013, 11:23 AM
Pm sent
Old 10-04-2013, 03:49 PM
$175
0 Ohm resistance
Patented* design
Old 10-08-2013, 12:44 PM
G-Load Brace
MAF Sensor
Valve Covers
Old 10-08-2013, 01:20 PM
A detailed break-down of the 2010-2011 Camaro Twin-Turbo kit and its components are as follows:
2 x PTE6265 Turbochargers with 4” Inlet Compressor ducting – Each capable of 65 lbs/min
Turbos are V band mounted on inlet and outlet to insure easy rotation, solid mounting and best of all there are no nuts and bolts entering or exit turbo body
2 x PTE 46mm Waste Gates Insure Maximum Control Over the Monster Turbos. Waste Gates Include Adjustable Springs to go from 4.5psi to 15psi (We factory set them at 7lbs)
All stainless steel and Heat temperature coated exhaust system components ensure a lifetime of reliability
1 x 50mm Tial Blow Off Valve
3 x Largest Front Mount Intercooler are Hi flow Bell cores with 3.5” inlets from turbos and a single 4” discharge pipe feeds direct to the throttle body. Intercooler Tanks are Black Powder Coated to Extract Heat Yet Fins Remain Untouched
Fiberglass Reinforced Silicone hose couplers ensure durability for year to come – no expense was spared
All the necessary Vacuum ports required to assist in installing the boost controller
1 x Oil Scavenge Pump & Brkt
Thermal Heat shielding for all effected lines
GMS Oil Feed & Return Line Kit are all precision clamped and crimped to ensure leak free connections
GMS/TTi 3.5” 6061 Aluminum Intercooler Tubing for lighter weight and better heat dispersion
GMS/TTi 4” 6061 Aluminum Charge-pipe
GMs/TTi 4” Aluminum Intake Tubing w/K&N Filters and K&N “Hydro Shields” for extended dust/dirt/water protection
GMS/TTi Aluminum Lower frame cover to ensure debris free road travel
The only TT kit that does not hang below the frame rail, ensure plenty of ground clearance
AEM Windshield Washer Bottle & Accessories
Polished Oil Cap w/oil return
Retains Factory Engine Cover
We offer many options from short blocks and long blocks to various turbo size upgrades and color choices. Factory Silver Powder Coated Tubing – Special Colors Available on Request.
Video was from 2010 our kit makes well over the power that power now
1200hp Camaro engine
BUILDING VIDEO
Quick Reply: Huge sale from granatelli motor sports
