what gap for ngk t-55 for a 12 to 1 compression 418 ls3?
I had the tr6's gapped at .40 BUT I had this annoying misfire! Talked to a few shops from all over abd one Jannety shop knew what I was talking about and said to get rid of them abd use AC Delco 41-104's. I threw them on and I see a MAJOR improvement. Gapped at .40 as well. It's a plug with the same heat range as a tr6 but it's an iridium tip. Just my .2
Even though the chambers on the square port stuff seems to want more timing advance than a comparable cathedral port head motor that is a lot of timing on that plug in that motor with that compression.
Play with it at the least and see what the car wants at the track.
MPH gain and loss at the track is the best tell tale sign for whether your car likes the amount of timing you are giving it or not.
Interestingly enough my car on motor ran faster at the track with the amount of timing used that made the least amount of hp on the dyno versus the amount of timing that made the most hp, but ran slowest at the track.
I did some research on the TR55 and sent an email to NGK.
As an engineer at NGK explained it, the TR55 is designed to be gapped at .055"-.060. The reason is if you bend the ground strap to achieve .035" - .040", the it ends up looking like a "J" rather than an "L" which results in accelerated erosion because the strap is not parallel to the center electrode.
Buy the TR5 if you want to gap at .035" - .040".
As for the heat range, if your car makes ~100 hp more than stock, you may want to look closer at TR6 or if you want an iridium plug for longer service life, look at the AC Delco 41-104 (or equivalent). Autolite makes an equivalent which I hear is good quality.
