after racing an srt4. engine shuts off and knocking
Old 09-11-2012, 07:38 PM
autogeek23's Avatar
Default after racing an srt4. engine shuts off and knocking
ill do a kill story thread later once the guy send me the vid. he is being slow as hell.
so after the race i let off at what ever rpm(not redline) in 4th as i was approaching a car in traffic. i get over behind the neon slowing down and notice my engine is off. doesnt seem like it wants to start and i get it started giving it throttle while cranking.
it will not idle at all. i have to keep it alive with throttle. i pull over after getting off the highway and pop the hood. nothing obvious. its hard to start so i give it throttle and it starts. we go back to the parking lot and on the way back i am downshifting to slow down. at about 2500 rpms i hear a knocking. get back and let the guys at the meet hear it. i have only heard the knock noise from the driver seat. so im not 100% sure how it sounds.
i have it towed home. disconnect the neg battery cable like an idiot. now the codes are cleared.
this is the only thing i find without going to deep into it.
http://s398.photobucket.com/albums/p...oserocker2.mp4
the rocker bolt is tight. all rockers got torqued to spec.
mods done 3k mi ago. Raptr Cam kit, dual valvesprings,LS7 Lifters.
the lifters were in Mobil 1 5w30 for 24hrs.
i tried putting a different rocker where the loose one was. was still loose.
Collapsed lifter maybe? im kinda pissed if it is. seeing how they are new.
oh and im rev limited to 6300rpms and i didnt hit the limiter once that race
engine is done. spun bearing. got it to run today and after it warmed up. i increased the rpm slowly and around 2500 it started knocking loud and i let off and it made a loud screech and died.
5.3? LS1 shortblock and do rod bolts? trying to keep it budget friendly.
Old 09-11-2012, 07:47 PM
got milk??'s Avatar
How is your oil pressure? Did you replace the pushrods with your cam swap?
Old 09-11-2012, 07:50 PM
autogeek23's Avatar
seemed normal. 20psi at lower rpms when warm. after racing it usually sat there. i revved it up to 6k when sitting on the side of the road and didnt hear a knock and oil pressure went to 40 psi. seems normal when not loaded.
yes cam kit cam with new pushrods. i checked and where the rocker is loose the pushrod is NOT bent. the valve spring is not broken. leads me to believe the lifter collapsed. brand new LS7 lifters
oh and new oil pump was done 13kmi ago.
Old 09-12-2012, 10:32 AM
autogeek23's Avatar
bump. still waiting on racing vid
Old 09-12-2012, 10:50 AM
autogeek23's Avatar
should i have bought the comp cam high energy lifters? or the Caddy Lifters??
Old 09-12-2012, 11:34 AM
LS1Tech Premium Sponsor
Sales3@Texas-Speed's Avatar
Did you measure pushrod length? Also, what preload do you have on those lifters?
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old 09-12-2012, 11:57 AM
autogeek23's Avatar
pushrods are 7.400.
come to think of it, i dont think i set or measured preload.
i installed the rockers the TDC Method.
Old 09-12-2012, 03:57 PM
autogeek23's Avatar
engine is done. spun bearing. get heads n cam done at 167k, now at 171k the engine is done.
Old 09-12-2012, 05:13 PM
Gunslinger09's Avatar
How bad? Can you pick up a stock crank and put it back with new rings and bearings? Or did it damage the block too?
Old 09-12-2012, 05:51 PM
autogeek23's Avatar
i dont even have it apart. idk if im gonna take it apart anytime soon. dont have money to fix it now so im probably gonna take my time with it and have it ready by next spring.
its in my grandma's garage and there isnt a ton of space. its a 2 car. im hoping its a rod bearing. maybe some rod bolts got stretched.
Old 09-12-2012, 07:59 PM
cabel1's Avatar
I have my 98 LS1 with a trex in it for sale. Been 11.91 in my car.
Old 09-12-2012, 11:42 PM
autogeek23's Avatar
i might be buying a LQ4 locally. but thanks
Quick Reply: after racing an srt4. engine shuts off and knocking
