Cam specs..any idea of HP projection/drivability?
LS1Tech Sponsor
Received 1,120 Likes
That sounds like it should be a good street combo that will have a noticeable rumble. Most of the power will be in the midrange of the RPM which will make for great drivability.
LS1Tech Premium Sponsor
If it's a 5th gen, it's amongst the largest camshafts that can be installed without having to flycut pistons. Also, the duration has as much to do with chop as the LSA does (overlap)...this cam on a 116 LSA will still chop hard. The lift is just fine and will work well with the stock heads.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
How does the custom cam you guys specd for SUPER CHEVY ("Monster Mouse" July2012) idle ? Would this be a decent street cam for a TSP 417/PRC 250cc heads in a 3:42 rearend and 4L65e trans? Would it be to big for a LY6 with the lower CR & CID? I want to cam the LY6 untill I save the coin for the TSP stroker.
thanks,
Jim
MAtt,
How does the custom cam you guys specd for SUPER CHEVY ("Monster Mouse" July2012) idle ? Would this be a decent street cam for a TSP 417/PRC 250cc heads in a 3:42 rearend and 4L65e trans? Would it be to big for a LY6 with the lower CR & CID? "Monster Mouse" artical (July2012)
thanks,
Jim
thanks,
Jim
__________________
http://www.superchevy.com/technical/.../photo_05.html
That cam in a heavy camaro will make killer power without sacrificing low-end or mid-range torque.
My goals are as much peak whp as I can get but still have some lowend and be able to keep it fairly street able above 2000rpm or so.
