LS2/LS3 topend build - Shortbloack clearence questions
Alright so im assembling my shortblock here tonight, and i have some questions.
Info:
Fresh LS2 Shortblock
Procomp CNC LS3 heads milled to 64cc
Ported LS3 intake and 92MM TB
Ed Curtis Custom grind
Crank was polished and the oil holes chamfered
ARP rod bolts
Bearings and specs
Mains are CLevite 77 bearings, came back with .0019 on all the mains
Rods are Calico coated clevite bearings Ranged from .0018 -.0019
DO this tolerances seem acceptable to you guys? Car will be a weekend toy and occassional street machine. Rev limiter is set @ 6,900.
Thanks in advance
Info:
ARP rod bolts
Bearings and specs
Thanks in advance
LS1Tech Premium Sponsor
If that cam is in the 23xº range @.050, and your heads are ported GM castings milled to 64cc, I would be very careful with piston to valve clearance and MEASURE (assuming no flycutting or other valve reliefs in pistons)!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Without knowing the valvedrop on those heads before or after milling, I can't say whether or not it would fit. I have never had the chance to check the drop to see how they compare to stock.
__________________
We used to rent them out and never got them back...so we stopped messing with it. I'd jump on Jeg's and buy them, or maybe post a want to buy thread in the classified section here. Maybe someone has a set collecting dust that they would let go of!
__________________
