500rwhp LS2 6.0L & Auto... Possible?
Old 11-11-2012, 02:28 AM
BOTTLEDUP's Avatar
Default 500rwhp LS2 6.0L & Auto... Possible?
Hi guys thought I'd bounce this one past you and get some opinions as to whether.this is possible or not.
Putting together a combo for a guy with a VZ Commodore (model prior to the G8) running a 6.0L LS2. At this time the car is completely standard, planned combo as follows:
TEA ported TFS 225cc heads, 60cc chamber
Ported FAST 102
102mm NW throttle body
OTR MAFLESS intake & airbox
FAST fuel rails
YT Ultralight rockers 1.7:1
1 7/8" 4-1 long tube headers to dual 3" system
Comp 54-460-11 cam.
3800 stall with lockup.
Mainly after opinions on the cam, do you think 235/243@0.050 on LSL lobes will be 'enough' to get close to his goal? I personally don't expect 500rwhp, the Mainline dynos we use down here read lower than the Dyno Dynamics & Dynojet units, but if we could get into the 480-490 range that would suffice. Oh yes and its a stock short block, not coming apart but we will flycut pistons if required.
Thanks!
Old 11-11-2012, 07:55 AM
Tainted's Avatar
People have hit 500rwhp with ls1 cars, i def think you can reach 500 as well, HOWEVER...
I hope you realize, that with the stall you will never actually get to see that 500 number come across from the drivetrain loss
Old 11-11-2012, 08:32 AM
30th t/a's Avatar
This should help:
https://ls1tech.com/forums/dynamomet...ack-times.html
Old 11-11-2012, 09:24 AM
Tainted's Avatar
Also Pat G gas a g8 with afr 230 heads making over 500
Old 11-11-2012, 11:40 AM
chrs1313's Avatar
https://ls1tech.com/forums/dynamomet...4-10-11-a.html
My car was an a4 but was locked converter on dyno jet
I would go with 239/247 lsl/lsl on 111+4
Old 11-11-2012, 11:44 AM
litle88's Avatar
TFS heads for the win! I'm with stupid ^^^^^^
That's a very healthy cam and it is a 113+3 with .621/.624 lift so I believe you might need to fly cut but that's nothing. I believe you'll be really close with those heads touched up by TEA!
Old 11-11-2012, 12:44 PM
Tainted's Avatar
Nice, im sure that run was with converter locked
Old 11-11-2012, 06:05 PM
chrs1313's Avatar
yup ^^^ also 12 bolt 4.10 gears and 28" MT drag radials
Old 11-12-2012, 02:45 AM
BOTTLEDUP's Avatar
Thanks for the info, I modelled that up in EA Pro and it shows a decent increase over the 'off the shelf' LSR grinds. Flycutting if needed isn't an issue, plan is to run the compression ratio into the mid-high 11s.
Old 11-13-2012, 02:50 PM
Pimp Prix's Avatar
Converter had to be locker. Those number are hard to come by with a big loose converter.
Quick Reply: 500rwhp LS2 6.0L & Auto... Possible?
