Looking for the best cam from texas speed performance
Old 11-11-2012, 07:19 PM
mullahi's Avatar
Default Looking for the best cam from texas speed performance
Got 2005 ls2 corvette c6 it has filter and headers only but im looking for a good cam kit that I can handle with the zo6 and im so confused there are lots of cam
Btw do I need clutch?
Oilpump ?
Fuel pump?
Or cam and push roads and sping valve are just fine
Any other cams option
Old 11-12-2012, 04:12 AM
bww3588's Avatar
If this is the end of your mods, go with a custom cam. If not, I'd just wait the cam out until you decide to Do heads...etc.
For a custom cam, I recommend Geoff@eps
Old 11-12-2012, 04:34 AM
Funkster's Avatar
As stated above, you should decide on your goals.
Camshafts are very different in design based on all motor, nitrous, forced induction, etc. Not to mention what you are looking for as far as drive characteristics, power range, rev range, etc.
Old 11-12-2012, 05:58 AM
Tainted's Avatar
You sound like you have no idea what you want, or what to do. And im here to help
1.) Determine your goals
2.) What is your budget
3.) Is this car daily driven? Track car?
The MINIMUM for a cam swap should include but not limited to:
Cam (duh)
Valve springs, locks, retainers
Pushrods
Timing chain (ls2 will suffice)
Oil pump (not a absolute must but it is HIGHLY recomended)
Gaskets and bolts, and fluids.
Quick Reply: Looking for the best cam from texas speed performance
