looking for cam for my 2005 corvette
Hey.. i just wanna ask about some cams kits found them in texas speed.
i got stock ls2 corvette 2005, it has filter + headers without tune.
so now im looking for daily use cam with the highest power i can make with
the cam that i can get between 400-450 whp.
i know that cams without tuning is nothig .
i know little bit about cams but i am lookig for the best one that i can drive my car everyday with the highest power that i can make
the first choice ive seen is
1-texas speed 228R Cam 113 or 114 LSA + spring kit and push rod
2-torquer v .3 cam 111 LSA + spring kit and push rod
3-texas speed tsunami cam 111 LSA + spring kit and push rod
any more cams?
do i need :-
oil pump?
fuel pump?
injectors ?
water pump?
what size do i need for spring valve 650 or 600 is fine?
what size do i need for push rod lenght
any more cams?
do i need :-
oil pump?
fuel pump?
injectors ?
water pump?
Was this thread not good enough for you? Why don't you answer some of the questions on there to get better help than just posting the same exact thread?
https://ls1tech.com/forums/generatio...dify-help.html
Best all around cam for Ls2's that are in my opinion good cams are the vengeance Vrx5 cams. Call Ron and he'll be glad to set you up with a kit.
You always buy the springs that are matched to the cam.
Yes I would always upgrade pumps to melling 10296.
Yes upgrade the pushrods to a chromoly, if you decide to mill the heads then you length you'll need a different length, if not then a 7.4 is what you'll most likely be needing, again Vengeance will have all of that for you.
Water pump--- how many miles on it? Because it will need to come off for install and if its off and you have lots of miles on it then I'd look into one a GM one cause others suck lol just my .2
Injectors--- if you do end up needing bigger then I'd send mine out to get resized for more flow. I resized my old Ls1's for my 416 here: http://www.stiegemeier.com/injectors.html
So far so good.
I'd also get a katech c5r chain.
Just my .2 bud
So far so good.
Just my .2 bud
Thanx for the good words!! If we can help you guys out do not hesitate to call/email.
So far so good.
Just my .2 bud
So far so good.
Just my .2 bud
