ARP Rod Bolts
Old 11-24-2012, 05:33 PM
LongIsland63SS409's Avatar
Default ARP Rod Bolts
Low mileage LY6.
Considering changing to ARP rod bolts and will be resizing the rods.
Does the rotating assembly need to be re-balanced?
How good is the factory balance anyway?
Comments/feedback.
Thanks,
Mike
Old 11-24-2012, 10:45 PM
Received 3,360 Likes on 2,078 Posts
I wouldn't worry about the balance. The factory balance is close enough for 250k to 300k miles of usage. Why change the bolts? You adding boost or N20?
Old 11-26-2012, 11:41 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
It should not make a big enough change in mass that you would need to re-balance the assembly.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 12-01-2012, 11:55 AM
That's what I was thinking.
Thank you for everybodies feedback.
Just changing the bolts and resizing for cheap insurance.
I'll be taking the motor apart after New Years and will post some pics.
Car will be a street/strip car so I decided to keep the VVT.
1998 Camaro Hardtop V6 to LY6 conversion.
Can't wait to install the Texas Speed VVT 3 cam I purchased.
Thanks for the feedback.
Mike
Old 12-01-2012, 11:12 PM
2000PewterT/A's Avatar
Like the others said, the weight difference would be so slight there would be no need balance it.
Quick Reply: ARP Rod Bolts
