Push Rod length
Push Rod length
Hello all,
I tried searching but didn't find an answer.
I am wondering what pushrod length I will most likely need for a cam swap. It will be a Torquer V3 in an LS2 with stock heads/gaskets. The lifters will be replaced with ls7 ones and springs with prc .675 EHTs. I ordered the push rod length checker and 7.400 rods, but would like to not have to wait on parts as I will only have a few days to install the cam, headers, ls7 clutch, injectors, BAP, and driver side axle in my 06 CTS v.
Thanks for your help!
LS1Tech Premium Sponsor
^^Bingo! You really have to measure. There are too many variables to be sure of any guess. Anybody that tells you a length without the tool being in place is GUESSING.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
