cam advice on 427lsx with trickflow 245 heads
Old 12-08-2012, 04:17 PM
corvette_uae1's Avatar
Default cam advice on 427lsx with trickflow 245 heads
hi there
would like to know what cam will be the best for my n/a new engine 427lsx with 10.5 cr and trick flow 245 heads + fast intake 92 with throttle
im planing on having nos around 150 hp on nos
drivability is my last concern its a weekend car
any ideas guys ?
Old 12-08-2012, 09:05 PM
djfury05's Avatar
Why such low compression? I'd bump it up to at least 11.5:1 maybe closer to 12.1:1 if you can get pure 93 octane and have a good tuner available.
For the cam I'd get a custom grind done. Pat G has always turned out good results. I used Advanced Induction for my old LS1 custom grind and it was great.
Old 12-08-2012, 09:13 PM
TheLS1Lover's Avatar
Defiantly more CR, you can spray more than that on an LSX motor as well.
Old 12-08-2012, 10:27 PM
WS.666's Avatar
Get a custom cam from Pat G. He did the one for my 427ci LS3 and it's awesome.
Old 12-08-2012, 10:36 PM
djfury 5 and the ls1lover - i got the full engine with a really good prise with 200 miles on it thats why i wont change the pistons for now so do u think with n/a tune and a costum cam ill be able to reach around 550rwhp ? and add like 200 shot of nos?
ws66 i would like to try patrick g costum cams
and thanks alot guys
Old 12-08-2012, 10:46 PM
You can for sure make 550rwhp, the combo has to be just right though. 200 shot shouldn't be anything.
Old 12-08-2012, 10:48 PM
WS.666's Avatar
550 is easy with a properly built 427.
Old 12-08-2012, 11:02 PM
ls1 lover and ws66 thanks guys for the help
Old 12-09-2012, 01:49 AM
jmgak47's Avatar
Need to know the trans and converter setup, if a auto...
Old 12-09-2012, 05:50 AM
Eliesor's Avatar
Old 12-09-2012, 07:28 AM
jmgak47 its a manual 6 speed with ram twin clutch
eliesor good to here that
Old 12-09-2012, 09:48 AM
STAR's Avatar
hi there
any ideas guys ?
Contact Brian Tooley! He will set you up with a cam and valvetrain to run reliably and make great power. He also runs a set of TF 245's on his personal combo.
Old 12-10-2012, 07:06 PM
poopman's Avatar
X2 for Brian Tooley he designed the head
Old 12-14-2012, 03:22 AM
hymey's Avatar
255-271-115,LSL lobes , but more comp, 12.0:1 with 30-35 thou quench.., The fast hurts the top end, spreading the lobe centres helps it hold on but you drop cylinder pressure doing so. So increase static compression to compensate.
Old 12-17-2012, 09:59 PM
Snyper's Avatar
Im running a 434ci with TFS 245s and the cam im running is a 247/251@112+3
Old 12-18-2012, 01:04 AM
jmgak47's Avatar
Your compression is pretty low, I would bump it up to 11.5-11.75:1 if you can.
Here is my recommendation...
247/263 .660/.660 @ 1.8 rr 112 LSA 110 ICL or (.624/.624 @ 1.7 rr)
It will have roughly a dynamic compression of 8.35 if you go with a 11.75 static compression, which will keep it 93 pump gas friendly.
Brian Tooley ran a 251/266 .660/.660 @ 1.8 rr 115 LSA in his 454 LS7 build which had a FAST 102 mm and TFS 245cc heads.
Old 12-19-2012, 04:20 PM
Sales@Tick's Avatar
If you'd like some advice, give me a call at the shop or shoot me a PM. I've done a lot of TFS H/C/I set-ups, honestly they are fairly easy to cam and a monkey could pretty much do a N/A cam for a cathedral port headed motor.
Old 12-20-2012, 02:59 AM
LilJohn's Avatar
Yea... well if a monkey can do it... you shouldnt have a problem... lolol.
Geez dude... leave yourself wide open whydontcha.
Old 12-20-2012, 10:54 AM
Sales@Tick's Avatar
Hey, what are you doing up so late....isn't it past your bed time mmmmhmmmm?
Old 05-13-2013, 10:42 AM
thanks guys well u all suggest i raise the cr for n/a setup therfor ill swap a kennebell to my setup i always wanted a kenne bell supercharge to get high hp numbers 800+
martin trick i will call and ask for other project in mine
thanks all u helped me alot
Quick Reply: cam advice on 427lsx with trickflow 245 heads
