Hp tuners / VVT help
Guys, I could really use some help here. I have a mast cammed LY6 w- LS3 intake, DBW and all the normal bolt ons as well in. 67 Cutlass conv. have a 4l85e stock converter and a 3:70 9" rear. Can't find a single person anywhere around me that can tune the VVT correctly. i have been burned twice so far. Found some great guys locally that finally have my car running well enough to drive around but it's no where as strong as it should be according to MAST and others running similar combos. They have never messed with a VVT motor so The VVT is turned off. Car is an absolute pig off the line, fairly decent in the upper rpm's but nowhere as strong as it should be for this combo.
I have a copy of my tune in an email they sent me but I can't open or do anything with it as I don't have hp tuners or a laptop... Only an iPad.
Any tuning gurus out there that wouldn't mind takings look at it for obvious problems if I emailed it to them? A guy in Jacksonville offered to help me but he couldn't open the file as he uses EFI live. I'm at my end of my rope here. Thanks!
Steve.
Steve.
Steve.
Steve.
Cannot MAST supply the correct VVT tables for your camshaft. It so have your tuner load them in. I know if you buy a TSP VVT camshaft they provide the correct VVT tables for the particular camshaft that you are buying.
