best ci for g8 gt twin turbo setup
Old 12-14-2012, 09:42 AM
ana LoooL's Avatar
Default best ci for g8 gt twin turbo setup
hi I want the best parts and best numper for ci stroker for 750 rwhp twin turbo set up
and did i need to change the Crankshaft or the piston & Connecting Rods
well be Enough
I hope some one tell me what is best heads run whith this cam
225 225 .581 .581 113
Old 12-14-2012, 11:33 AM
ana LoooL's Avatar
any one plz
Old 12-14-2012, 11:43 AM
Tainted's Avatar
theres no replacement for displacement.
Go witht he biggest bore you can, and no more than a 4 inch stroke. a 427 is probably your best bet.
you want a forged rotating assembly by far, and an iron block wouldnt be a bad idea either.
Oh, and that cam seems like a bitch cam, get something custom spec'd
Old 12-14-2012, 01:30 PM
2000PewterT/A's Avatar
I would definitely get a bigger cam if you plan on running bigger cubes. Nothing beats a custom grind.
Old 12-15-2012, 05:24 AM
ana LoooL's Avatar
ok but did the 364 ci well be good or i need to bigger cubes
and just piston & Connecting Rods well be good and safe for around 750 rwhp
I plan to running in 9-10 psi
Old 12-15-2012, 08:27 AM
Tainted's Avatar
I just told you bore it out as much as you can and go with a 4inch stroke. If you have a 4.030 bore that makes it 408 etc etc
Old 12-15-2012, 02:40 PM
ana LoooL's Avatar
thanks alot
Quick Reply: best ci for g8 gt twin turbo setup
