i am so confoused between cams!
Old 12-17-2012, 05:52 PM
mullahi's Avatar
Default i am so confoused between cams!
Hi... I have 2005 ls2 corvette c6 6.0L
and I am planning to modify the car by adding cam to the car
but...
I am confused between two cams and I need help to the most powerful cam
First cam is from taxes speed performance "tsunami"
second one is from vengeance racing performance "VRX5"
so whaat do you guys thinks about it or is there any one is better rather than these two cams
Old 12-17-2012, 08:47 PM
Knight-Z06's Avatar
Originally Posted by mullahi
hi... I have 2005 ls2 corvette c6 6.0l
and i am planning to modify the car by adding cam to the car
but...
I am confused between two cams and i need help to the most powerful cam
first cam is from taxes speed performance "tsunami"
second one is from vengeance racing performance "vrx5"
get a custom grind cam
Old 12-18-2012, 04:20 AM
badassracing's Avatar
VRX5. I know a guy that runs a comp custom grind with almost identical specs in a 6.0 with AFR 205s and he made 475rwhp. The tsunami intake lobe is very aggressive and probably little gain if any. With that said both cams are kinda big for stock heads and compression IMO.
Quick Reply: i am so confoused between cams!
