Will be running a LQ9 stock bttm and and prc tsp LS3 heads. Currently running a G5x2 but after some research it doesn't look like the cam will work well for the new setup.
Depending on whether you chose the solid stem or hollow stem intake valve either my Stage 1 or Stage 2 "Street Heat" cams for the LS3 would work well, or if you really wanted to make some big power "The Polluter" for LS3.
