setting up 6.0 vette to reach the maximum HP
Old 12-21-2012, 07:03 PM
mullahi's Avatar
Default setting up 6.0 vette to reach the maximum HP
i have corvette 2005 LS2 6.0L
it has cold air intake and L/T headers with zo6 transmission with cluch and ECU.
i am planning to maximes the highest HP with my car the driveability is not an issue for me
i will install texas speed tsunami cam kit
melling oil pump
spark plugs ngk tr5
but i have some questions, do i need water pump, fuel pump or injectors ?
if i do then what is the best suggestion for me?
what LSA shell i need to take for the camshaft ?
what good size for push rod or spring valve ?
any thing do i need to change instead of this camshaft is so what other good camshaft.
Old 12-22-2012, 09:28 AM
Imstock2's Avatar
You'll see the most gains depending on your head choice.. Is money an option for you? Money is the only limiting factor
Old 12-22-2012, 11:17 AM
DACTARI's Avatar
mullahi, you keep starting threads then you don't respond to people's questions when they want clarification. you are wasting people's time.
Old 12-22-2012, 01:39 PM
litle88's Avatar
This will increase your power by at least 150 hp!
http://kalecoauto.com/index.php?main...products_id=36
But you have to use it with this
http://kalecoauto.com/index.php?main...products_id=37
And since its hot over there in the sandbox you'll need this so you won't blow it up!
http://kalecoauto.com/index.php?main...products_id=43
Keep us posted with your progress cause I'm subscribing AGAIN!
Old 12-22-2012, 02:58 PM
Imstock2's Avatar
Yes lol
Old 12-22-2012, 02:59 PM
Knight-Z06's Avatar
lol lol
Old 12-23-2012, 05:44 PM
mullahi's Avatar
didnt understand
__________________
01 Ws6,m6, ASC#618 of 1583,AES built forged 416,ArP'd,Morels,LPE Ls3 heads 12-1 comp,FAST 102 by chris1313,N/W 102 Tb,Racetronix F/P,65lb inj,C5r T/C, LsR 243/259 .624 114+3,P/B 10% Ud,Kooks 2" headers,Kooks yp,Dmh dual c/o's,COMPLETE UMI suspension,SLP Torque arm,viperized T56 by wrencher,Textrellia,Moser 9" spooled w/4.11's & 35 spline axles, Koni 4th Gen's,BMR springs,Sjm abs delete,magna flow CB, StraightLine Tuned!
Old 12-23-2012, 05:45 PM
mullahi's Avatar
money isnt an issue for these modifications
Quick Reply: setting up 6.0 vette to reach the maximum HP
