416 and cams
Old 01-19-2013, 09:59 PM
gnfan's Avatar
Default 416 and cams
I was looking for input on what guys are using for cams in heavy cars like a GTO with a 416.
Old 01-19-2013, 11:05 PM
FlamingTA's Avatar
Custom cam. In my 421 I have a 243/247 112lsa.
Old 01-20-2013, 09:47 AM
gnfan's Avatar
I should have added 416 with a LS3 top end.
Old 01-20-2013, 10:41 AM
litle88's Avatar
I used a 243/259 .624/.624 114+3 with a 9" and 4.11 gears and I must say I had two other options this one and these:
http://www.compcams.com/Company/CC/c...csid=1415&sb=0
http://www.compcams.com/Company/CC/c...csid=1416&sb=0
And I should of because I started to pull vacuum at the topend. As always always go bigger and my dumbass should of. Live and learn I guess
Old 01-20-2013, 10:45 AM
litle88's Avatar
I made 515/500 thru the 9" on a mustang dyno.
My best pass on 275/40/17 Nitto nto5r's was a 11.5@125.96 and 1.7 60's lol
I know I got a 10 second car but I ran out of money for the slick n skinny setup lol. Hopefully this year lol.
Old 01-20-2013, 11:10 AM
gnfan's Avatar
I drive my car a lot. May go to the track a couple of times a year. My heads are advanced induction ported LS3's. The cam I'm about to install is a 238/250 on a 115 +5. The car is a A4 with a 3600 stall.
Old 01-20-2013, 11:16 AM
litle88's Avatar
You got better exhaust duration so you'll be better off than me lol.
Old 01-20-2013, 11:18 AM
gnfan's Avatar
I hope it won't be sluggish with this heavy *** GTO
Old 01-20-2013, 11:32 AM
gnfan's Avatar
may as well list the whole set up....416 forged pistons crank rods,Ls3 AI heads,L76 intake Over the Rad air intake A4 3600FTI converter, 1 7/8 kooks headers. Motor was built at HKE..The car is a 05 GTO
Old 01-21-2013, 05:16 AM
FlamingTA's Avatar
Ya, if you are in a heavy full weight GTO, smaller is better usually. Don't go for a huge came to make big numbers, TQ will suffer.
Old 01-21-2013, 10:22 AM
gnfan's Avatar
238/250 is about to go in, I also have a 232/244 115+3
Old 01-23-2013, 09:55 PM
redgto4u's Avatar
Texas Giant v2 on a 112lsa. I have a pretty flat power curve from 4k on up. It doesn't like anything below 1800 though at part throttle.
Old 01-24-2013, 05:58 AM
WKMCD's Avatar
FWIW: The best cam I ran in my 403 build was a 230-240 with lots of lift. That build made 530/480 with 400Ft\lb of RWT from 2200RPM up. From my experience the sweet spot on the intake side is 230 to 234 degrees and the lsa\icl 111-112.
Just my $.02
Old 02-18-2013, 11:14 PM
gnfan's Avatar
What are all you other guys with 416's running?
Old 02-18-2013, 11:25 PM
LS2GS's Avatar
I got a custom grind from Wegner Motorsports, My 415 made 654hp at the crank and over 500 ft/lb of torque from 4k through 7k rpm!
Old 02-19-2013, 04:35 AM
Dyno Junkie's Avatar
Should be able to go a lot lower than 11.5 on those drag radials.
I've managed 1.52 60's on 265/40/18 M/T's.
Old 02-19-2013, 05:59 PM
litle88's Avatar
It was a hot and humid day, the Nittos were not hooking past 3500!
Ill be getting some slicks and skinnies this spring so I know I'll get a 10 sec slip.
Quick Reply: 416 and cams
