Lq4 crank inside ls7 block?????
I have a ls7 block. Bare.
im wondering if i could throw a wet sump rotating assembly from an lq4/9 into an ls7 block.
Is this possible?
Is this possible?
I have a fully built lq4. But was given this ls7 block from my buddy down south.
wondering if i could transfer my forged rotating assembly to the ls7 block.
Wondering if it will bolt.
? Anyone
? Anyone
It's a 4.125 bore so you would need pistons. Ask one of the vendors if the crank would work. It would be interesting to see what kind of power that set up would make. A 387 CI motor with a big bore and relatively short stroke should turn a ton of RPM.
