58x to 24x conversion?!?
Old 01-26-2013, 12:11 AM
Jadedbird's Avatar
Default 58x to 24x conversion?!?
I look everywhere but i only fing the conversion wiring from LPE.
Can you change a 58x engine into a 24x ?
Old 01-26-2013, 12:12 AM
bww3588's Avatar
Sure, take the crank out and change the reluctor wheel.
Old 01-26-2013, 11:15 AM
Jadedbird's Avatar
Sorry im new to internals.
Could i use all the internals from a 6.0 lq4 on a ls2?
And would 317 heads work on a ls2 or ls3?
Old 01-26-2013, 11:41 AM
Tainted's Avatar
317 heads came on lq4/lq9 iron varients but they work across all platforms.
Most of the lsx stuff is interchangeable
Old 01-26-2013, 12:00 PM
Jadedbird's Avatar
Well i may pick up a ls3. Throw some 317s on it with some boost goodies and use my ls6 intake and get a good crank with a 24x reluctor.
The ony thing is im so indecisive...
Would the front accessories an oil pan off an ls3 fit in a fbody?
Old 01-26-2013, 12:29 PM
Tainted's Avatar
That ls6 intake is a pos for what youre wanting to do along wih those 317s. If you get an ls3 stick with ls3 heads, they have a 68cc chamber, outflow the 317s by a longshot, and the ls3 intake is lightyears ahead of the ls6
Old 01-26-2013, 01:26 PM
Jadedbird's Avatar
Duely noted
Old 01-26-2013, 01:27 PM
Jadedbird's Avatar
Will that ls3 oil pan fit an f body?
Old 01-26-2013, 11:21 PM
lizeec's Avatar
Be more specific on the F Body? What Year? On the Reluctor you can get just the Reluctor from the crank changed to 24x or change the whole crank, or use the LPE converter box.
Old 01-27-2013, 07:15 PM
Jadedbird's Avatar
I dont want the box. Lol
But i found that dealerships sell the relucters for $20 or so
This may be going in a 99 trans am
I have sk many senarios running thru my head
Im think aluminum ls2 bottom end and ls3 top end
Quick Reply: 58x to 24x conversion?!?
