Oil Leak possibly rear main seal?
Old 02-06-2013, 08:08 PM
t56transam's Avatar
Default Oil Leak possibly rear main seal?
Shortly after replacing my clutch I noticed my car began to leak oil from in between the motor and bellhousing. Then about a month later in the higher rpms my clutch was slipping. Just took the clutch and saw oil everywhere. I took a picture, should I replace the rear main seal?
Old 02-06-2013, 08:39 PM
S10xGN's Avatar
Did you manage to dislodge or knock the cup plug out of the rear of the crank while doing this clutch change?
Old 02-07-2013, 05:56 AM
Jontall's Avatar
Looks like the welsh plug in the crankshaft to me too. Did you change the pilot bearing? If so, you dislodged the plug or it just may have started leaking.
GM part # 24502262 Plug, Expansion Plug Cup Shape 1" Steel (CR/SHF HOLE) (0.293)
Old 02-07-2013, 04:17 PM
t56transam's Avatar
I did replace the pilot bearing. How hard it is to replace?
Old 02-07-2013, 04:36 PM
Jontall's Avatar
It's hard to get out. Drill a small hole (grease on drill bit to catch metal shavings) in the lower part of the plug. Make the hole just large enough to thread in a long self-tapping sheet-metal screw. Get a grip on the screw and pull out the plug. Clean the hole very well (no oil), put a bead of RTV silicone around the new plug and drive it squarely into the hole. Do not drive it in too far. Look at this: http://www.jasperengines.com/pdf/57L...gBushingTB.pdf
Old 02-28-2013, 12:25 PM
t56transam's Avatar
Finally got some time to pull the pilot bearing and I dont see any plug back there, so I think I may have pushed it back to far. Would it have fallen into the oil pan? If so how do I go about getting it out now?
Quick Reply: Oil Leak possibly rear main seal?
