What would you build ls3 427 or lq4 427
Old 02-09-2013, 07:09 PM
jdub38672's Avatar
Default What would you build ls3 427 or lq4 427
Hey guys needing some help and wanting some opinions. Currently I have an Ls3 block and L92 Cnc'd heads. I also scored a low mileage complete lq4 motor. I would like to build a 427 using the aluminum block 4.070 bore with 4.100 stroke. Then sale the lq4. Or should I build the iron block. I'm leaning toward the aluminum block because its already going in a heavy 04 Gto. Just wanting some options and past experiences with these combos. I could back of cubic inch and build a 418 with either block. The lq4 is complete so I migh just leave that alone. Someone help lol!
Old 02-09-2013, 08:56 PM
S10xGN's Avatar
My whole passion in embracing these engines is the aluminum block, so there's my opinion...
Old 02-09-2013, 08:59 PM
jdub38672's Avatar
Thanks S10xGN I was thinking the exact same thing. Plus I believe these about a 100 lb. weight difference
Old 02-09-2013, 09:48 PM
Gunslinger09's Avatar
If you have the block and heads already Ls3 definately.
Old 02-10-2013, 02:51 AM
Gray86hatch's Avatar
I would not go with more than 4" stroke
The stock bores are not long enough to support the piston at bdc with more than 4"
Tim
Old 02-10-2013, 08:56 AM
Jimbo1367's Avatar
^ what greyhatch said. LS3 418
Old 02-10-2013, 09:45 PM
yonerhottlt1's Avatar
LS3 hands down...
Old 02-10-2013, 09:55 PM
Tainted's Avatar
Ls3 will have a bigger bore, a better block, longer sleeves and you would be crazy, oh and its 110lbs lighter
Old 02-10-2013, 10:58 PM
MertezWS6's Avatar
Default Ls3
I got an LS3 block and in the process of doing a 418 build, so my vote's for the LS3 418
Quick Reply: What would you build ls3 427 or lq4 427
