6.0L+7.0L rotating assem.
is it possable to bore and stroke a 6.0L aluminum or iron to accept a 427{7.0L} rotating assembly? i got a good deal on a 427 asembley and was wandering if it can be done and not be a oil sipper.also what heads would be best of this set up ls6 or 317 castings? i will drive the car around town a lil and to the track more than anything. is forged pistons worth it? going to spray 200 or so on it. or will factory replacements do? and where do i get the titanuim rods from? gm only?
I'd do the 6.0 iron block bored to 4.030" and stroked to 4" to make 408 CID. Very strong motor if everything is forged and can easily make 500 hp N/A. Bonus is it can handle a lot of spray.
its possible with a .060 over LQ4/9 and a 4.125" crankshaft. but not a very street friendly setup because of skirt wear and oil consumption. Its more popular to go with a 408 (.030 over 6.0 block with a 4" crank) or a 370 (stock LS crank and .030 over bore)
