Help!!!!
Old 03-12-2013, 04:21 PM
work in progress's Avatar
Angry Help!!!!
I converted to an LS3 setup and need help running down a problem. Car runs fine at part throttle below 3600, as soon as you get in it it breaks up and won't pull (does seem to clean up a bit around 5k). I swapped coil packs, ohm'd out wires, swapped plugs, got rid of the crappy ev1 adapters for the racetronix adapters and chased every wire I could possibly think of. All grounds seem good and no broken wires. Could it be the fuel pump is going out? Maybe a bad cam sensor? It only runs bad under load.
Old 03-12-2013, 04:56 PM
All suggestions welcome! I am pulling my hair out over this...
Old 03-12-2013, 05:16 PM
WKMCD's Avatar
Are you running an LS3 TB?
Old 03-12-2013, 05:17 PM
yes, it is a wilson manifold TB
Old 03-12-2013, 05:20 PM
What is weird is this all happened after I installed a new trans.
Old 03-12-2013, 05:25 PM
WKMCD's Avatar
Not that. Some people report tuning issues running the stock LS3 TB with the earlier PCM's.
Quick Reply: Help!!!!
