concerned motor swap.
just curious if theres anything i need to be aware of im changing my ls6 383 to a ls3 418. curious if oil pan will bolt back up. will parts interchange. is there any main pointers or concerns i need to know.? thnaks
The LS2 front cover will a PITA if you use a double roller chain. The boss for the bolt that holds the cam sensor in place will hit the timing chain and you will end up grinding the **** out of it.
Already getting intake and stuff for it.. and its a doubke rollmaster timing chain.. so idk what kinda cover is on it exactky.. the car been running in guys car for while...
