Thrust Bearing Failure #2
Old 03-22-2013, 06:19 PM
TransAm-Z's Avatar
Default Thrust Bearing Failure #2
For the 2nd time in 2 years I have wiped out yet another thrust bearing on my turbo Iron LS motor.
Below is the link to the first bearing failure.
https://ls1tech.com/forums/generatio...g-failure.html
After the first bearings failure I chamfered the bearing corner to better oil the thrust bearing, ran 1/2" cooler lines to a large plate style cooler, removed the spacers between the flywheel and the converter to get to 3/16" clearance.
This thrust bearing lasted all season around 30-40 1/4 mile runs and about 3000 miles on the street.
    • I need to verify the perpendicularity of the crank to the thrust bearing. Does anyone have a spec showing what this value should be?
    Old 03-22-2013, 06:30 PM
    3rdCoastPowerSports's Avatar
    out of curiosity what was your crankshaft end play set up at?
    Old 03-22-2013, 07:38 PM
    TransAm-Z's Avatar
    The first time I think it was abound .006" and .0075" the second time after the crank was welded and repaired.
    I am kicking around the idea of removing the thrust bearing and adding a four-point contact angular contact bearing to the front of the crank. I would end up adding it to the crank hub and modifying/remaking the timing cover. I just don't know if a bearing would survive in such harsh conditions!
    Old 03-22-2013, 08:00 PM
    lazaris's Avatar
      You first need to verify what your transmission line pressure is, then verify what your converter feed pressure is. Also what converter are you using?
      Old 03-22-2013, 08:21 PM
      TransAm-Z's Avatar
      Converter is a 5-disk lockup Vigilante 3500 stall.
      I guess I need an easier way to get the trans out without pulling the entire motor... Maybe It's time to cut an access panel into the floorboard.
      Old 03-22-2013, 09:22 PM
      Gray86hatch's Avatar
      Time to step up the converter.
      Asking for problems with the stuff you have
      Tim
      Old 03-23-2013, 12:48 AM
      Sawzall and Welder Mod
      Whistler's Avatar
      Who repaired the crank?
      Old 03-23-2013, 11:55 PM
      TransAm-Z's Avatar
      I had OHIO Crankshaft Weld the crank up and regrind. Only issue I saw with that repair was a sharp edge on the thrust face where the weld was just a bit thin.
      I guess I will take the crank back to them for round two. Just got the motor disassembled, and everything looks good except for the thrust surface. The thrust surface on the crank is ate up pretty bad once again.
      Old 03-24-2013, 06:55 AM
      RezinTexas's Avatar
      got any pictures? sorry for your troubles.
      Old 03-28-2013, 09:03 PM
      TransAm-Z's Avatar
      Well the crank is out to be fixed and I have been looking in depth at the converter feed circuit and I am a little confused about the spring mod I made with the Precision Viigilanti Converter.
      Here is a link to the mods they have you make for their converter.http://converter.com/book_pump.htm
      The extra spring added in the converter limit valve only allows the valve to shift about .06", so I don't think it's regulating pressure to the converter properly. In addition the cross drilled hole would be directly into the high pressure side of the pump which would increase the flow.
      It appears they are increasing the pressure in the converter when the torque converter is released (unlocked) which could be causing my bearing failures.
      Does anyone know why they are increasing flow/pressure to the converter and why I can't just remove the extra heavy spring they had me add?
      Attached Thumbnails Thrust Bearing Failure #2-cid_bfd5e3efcf8747db877028ef8f2ee57b-adminpc.jpg
      Old 03-29-2013, 07:49 PM
      S10xGN's Avatar
      Here's a good
      if you haven't already seen it. I've got PI Vigs in my S-10 & Mav, but they're both single disc w/o mods. Have you called PI and asked them?
      Old 03-30-2013, 09:39 PM
      TransAm-Z's Avatar
      Thanks for sharing! I did contact PI and they told me that the spring is there to boost torque converter pressure to 85% of line and keep the torque converter clutch from slipping under extreme conditions. They've been top notch to deal with, I just don't understand what they are telling me.
      What I need someone to explain to me is how does the converter limit feed circuit (where the heavy spring mod is made) affect the converter when it is locked up...
      The circuit below show the converter released (Not locked up), and I agree "regulated" fluid flows out of the converter limit valve, into the converter clutch shift valve, and into the torque converter release circuit.
      It then travels through the input shaft entering the converter, fills the converter, exits through the converter hub, and the flows back through the converter clutch shift valve exiting thru the trans cooler.
      The circuit below shows the torque converter locked up. Following the converter limit valve circuit I see the "regulated" fluid flow from the converter limit valve into the converter clutch shift valve, and then is directly diverted into the trans cooler.
      The pressure the torque convert sees for lock up is coming from a different circuit. The TCC (PWM) opens the TCC regulator valve, where line pressure is regulated then leave the valve. The regulated fluid flows to the converter clutch shift valve and is then sent thru the apply/return circuit to activate the TCC.
      Please correct me if I'm wrong, but I don't see how bumping up the pressure in the converter limit valve help keep the TTC lock-up from slipping.
      See link for detailed 4L80E schematics
      http://www.scribd.com/doc/34146059/4L80E
      Old 03-31-2013, 09:14 PM
      S10xGN's Avatar
      I know nothing of the internal circuitry, sorry. There are a few guys you can contact, mostly from the turbobuick board:
      Quick Reply: Thrust Bearing Failure #2
