Aluminum 6.0 stamp # 51023?
Old 04-18-2013, 02:28 PM
Jadedbird's Avatar
Default Aluminum 6.0 stamp # 51023?
How do i tell if a 6.0 block is iron or aluminum?
This has a number stamped 51023 on it.
Anybody?
Old 04-18-2013, 03:33 PM
RAMPANT's Avatar
Iron will look a lot different, more grey than silver, weigh 70lbs more and a magnet will stick to the out side of it. If the heads are off, there will be no sleeves in the iron block (shouldn't be at least)
Post a picture, you should be able to tell by sight.
Old 04-18-2013, 03:45 PM
Jadedbird's Avatar
Old 04-18-2013, 05:31 PM
newschool72's Avatar
Aluminum. At least it looks like it. Iron would be much darker and it looks like it has been around a while, so rust should be around the bolt holes and scratched areas.
Old 04-18-2013, 05:36 PM
RAMPANT's Avatar
Pretty sure it is the aluminum, but go grab a magnet off the fridge and slap it on the side of the block. If it hits the floor she is aluminum.
Old 04-18-2013, 10:38 PM
Jadedbird's Avatar
50,000k. Just bought her. Havent picke her up cuz i havent sen the rest of the money. Was supposed to tonight but had something come up.
Ill be sending the remaining balance friday.
Going with a l92 top end
Old 04-18-2013, 10:55 PM
lilaaron233333's Avatar
thats and aluminum block. iron block wouldnt get thoes white spots they would be brown or rust color not white.
Old 04-20-2013, 11:57 AM
Jadedbird's Avatar
Mkay well it will be here in a week or so. Ill stick a magnet to it when se arrives
Old 04-21-2013, 03:22 PM
ramairws6's Avatar
More than likely an LFA hybid motor out of a newer truck or tahoe...
Old 04-21-2013, 09:02 PM
Blackpanther99's Avatar
Looks aliminum. Doest look like my 6.0 block, mine looks a lot darker.
Quick Reply: Aluminum 6.0 stamp # 51023?
