LS noob question
Old 04-23-2013, 08:24 AM
01blklightning's Avatar
Default LS noob question
I'm on a budget build due to the fact I am also house hunting.. I came across a deal on a motor for my camaro roller. It's 1500 for a low miles LQ4, comes with ls6 valve springs, ls6 rods, ls6 cam, ls2 timing chain, ls6 oil pump, slp header back exhaust, ls1 heads and 317 heads. I can't really have anything else ported right now due to saving money, but what head combo should I run with the stuff I mentioned earlier? Car will be dyno tuned once it's all together.
Old 04-23-2013, 08:32 AM
Deal also came with a stock rear end and 6 speed
Old 04-23-2013, 09:26 AM
outkast6991's Avatar
I'd run the 317's. if you can swing milling and a vj in the budget you'd be good to go
Old 04-23-2013, 10:50 AM
Kinda need to just throw them on if I'm gonna use them
Old 04-23-2013, 01:34 PM
Any more input?
Old 04-23-2013, 03:56 PM
87silverbullet's Avatar
Its kinda like a double edge sword here. You can put the LS1 heads on and bump up the compression but then you have a little less flow than the 317 heads and they lower the compression.
I say run the LS1 heads so you bump up the compression because you won't even use the extra flow of the 317's with just an LS6 cam.
Old 04-23-2013, 04:23 PM
Is there really much of a difference in horsepower? I intend in using a turbo down the line in 2 to 3 years.. But how drastic is the power difference for now going with the LS1 heads as opposed to the 317s?
Old 04-23-2013, 06:03 PM
In going with a turbo the dish of the LQ4 is going to keep your compression low 9.4:1 with the 317's and 10:1 with the LS1 heads. 10 might seem high but not in the LS world. It was back in the SBC world that 10:1 is high. You have a very efficient head compared to the SBC is the reason you can get away with more compression. I don't think you will see much difference in power from the 2 with that setup. Now if you were building a 370 with a custom turbo cam and a GT91 turbo in front, then that would be a different story.
Old 04-23-2013, 07:35 PM
Okay, so long story short, putting the LS1 heads on now instead of the 317s will do nothing. Especially if I plan on an STS in the future. Correct? Thanks for all the help man
Old 04-24-2013, 07:53 AM
l2mb's Avatar
just stick with what you have
Old 04-24-2013, 10:42 AM
Just put the LS1 heads on the lq4, you will be fine.
Old 04-24-2013, 12:12 PM
Blackpanther99's Avatar
I agree with him.
Old 04-24-2013, 08:09 PM
Well I have both heads and plan on a turbo in the future.. Al just glnna run with the 317s rather than have to rip the motor apart again in 2 to 3 years
Quick Reply: LS noob question
